#41 |
Some bikes that require a spacer above the springs to adjust the preload, this could be because they have no adjusters as standard or they may be fitted with springs which are a different length to the standard springs, (Progressives, for example), whichever is the case you calculate how much you need on a per bike basis, the rider will sit on the bike and you see how much suspension travel is used up, (sag), then you decide, using a formula dependant on Lunar position, riders shoe size and grandmothers maiden name*, how much sag it would be desirable to have and fit a suitable spacer above the spring.
* This is not true, it's really done by entering a pact with the Devil and a secret Druidic incantation.
#42 | |
#43 |
Generlly the new springs are longer than the standard ones, so you can just cut down the spacer you take out. Job done.
#44 |
Some are some aren't, if they are then you can as Rictus says just chop down the original spacer tube, if not then you can add washers, but I find it easier to use some tube cut to the relevant size, IIRC you need tube ~38mm in diameter for an SV, I use plastic pipe.
#45 | |
#46 |
For the 1st time ever in my life i wish i lived down south !!!!!!
Top Man Rictus ![]()
#47 | |
![]() I'll look forward to the idiots guide. |
#48 | |
#49 | ||
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#50 |
I've got a feeling this is going to be one of those shows that you would pay to go and see
![]() ![]() ![]() ![]() Yes I think this might turn out to be a bit of an earner here ![]() ![]() ![]() |
Front Springs - YET again. | DANINPLYMOUTH | SV Talk, Tuning & Tweaking | 82 | 23-06-09 02:23 PM |
Standard Front Springs ??? | shelleyamy | SV Talk, Tuning & Tweaking | 8 | 06-08-07 07:01 PM |
Front Fork springs | stev | SV Ecosse | 7 | 30-04-06 10:29 PM |
front springs | matsv650s | SV Talk, Tuning & Tweaking | 1 | 13-03-06 01:25 PM |
Buying ohlins springs from Demon tweeks | brolong22 | SV Talk, Tuning & Tweaking | 3 | 14-05-05 04:28 PM |
