Old 23-03-05, 08:49 PM   #41
madmartyn
Originally Posted by hall13uk
Originally Posted by jonboy
So what's wrong with 30mph? It'll get you to Soho.
rather not feels very dangerous just wish the garage would pull there finger out
wheres ya spirit of adventure? i once had to ride one of my bikes ten miles home with no clutch cable as it snapped loads of fun as it was rush hour and i had to ride through town lots traffic lights stall it put it in neutral wait for lights revs up bang it in gear and of we go, so i,m sure ya can ride yours at 30mph (aint that most of the speed limits anyway)
Old 23-03-05, 08:50 PM   #42
hall13uk
thanks but i just could not do it.
Old 23-03-05, 09:08 PM   #43
snoopy
Burnouts shouldn't feck up the clutch that much, I did it to my old Dunlop 220 and needed no adjustment afterwards.
It really sounds like you've burnt the clutch out. Once you've got the wheel spinning you need to let the clutch out completely rather than half-clutching it, which I guess is, and was, your problem.
I've never had to change a bike clutch before.
As for the brake that's an odd one. Fluid leakage should be obvious. Maybe's you've burnt through the pads as well!
Old 23-03-05, 10:41 PM   #44
Peter Henry
Got to echo Andrew I am afraid.It sounds like you have been screwing the nuts off the bike whilst slipping the clutch. You also must have been doing this for some time for such a difference to be noticeable.
I hate to be a pooper, but apart from just totally sh+gging the last bit of rubber on a tyre before replacing...I have never seen the point of this little trick.
Old 23-03-05, 11:48 PM   #45
Dan_SV
If you feel the need to spin it up (the hooligan in everyone does ), put weight over the front, dip the clutch, whilst grabbing the brake to further unload weight off the back tyre, DUMP the clutch with it low-mid revs, then modulate your throttle and brake together to wheel effortlessly along with the rear spinning + smoking somewhat.
It's not healthy for the bike as it does strain all sorts of things, but unless you do it all the time, it shouldnt do any real harm (apart from the obvious destruction of the rear tyre!). Slipping the clutch whilst trying to do a burnout is one of the worst things to do to a bike clutch, and its a poor method to do burnies anyway.
Like everyone says, adjust it first before deciding its fooooked. If you can't do it, then trust some of your local lads. If its buggered then they won't bugger it any more will they? Chances are they will sort it out, and you will be able to get to brands.
Dan
Old 24-03-05, 07:26 AM   #46
Sudoxe
Hall - Im only in bromley, I could pop down this afternoon/evening or tommorow to take a look, it is really only a 2min job...
Dan
Old 24-03-05, 10:33 AM   #47
hall13uk
YES PLEASE this evening would be great if you can fix it theres a free ticket to brands on monday in it for you honest (got one going spare a close friend can't go he's wife is ill) what time can you make around 7pm would be good for me, can't any earlier it's my brother's birthday!!! he's 8yrs old today.
Old 24-03-05, 10:39 AM   #48
hall13uk
the bike is actally in the workshop as i type but they dont know if they will get around to it today!! the guy says even if i did come and get it where would i get a clutch before monday anyway. he thinks the plates have gone.
Old 24-03-05, 11:01 AM   #49
Sudoxe
panic! panic! panic!
PM me your mobile, and ill come down.
Dan
Old 24-03-05, 11:52 AM   #50
jonboy
I know that Rictus fits a set of clutch plates in less than 30 mins (which includes two fag breaks ). If the bike is leant over far enough you won't even have to drain the oil apparently.
You'll also likely need a gasket.
