#41 | |
#42 |
Silver SV650SK3, Fuel exhaust |
#43 |
Hmmmm....seems we might have been trying to explain a phenomenon which doesn't actually exist!
Maybe people put the way the back wheel is more prone to locking up on downchanges with a v twin down to lots of engine braking. |
#44 | |
![]() So to sum up, 'Engine braking results from 2 major causes: 1)Engine friction and 2) the pumping losses caused by tring to pull air past a carb(s) closed to idle position.' The bike with the most engine braking - in that article - was the Yamaha R1 ![]() ![]() Just noticed what bike the guy who posted the article rides. Where do I get one of them mods for my SV? I'd love a girlie ass on my SV ![]() |
#45 | |
![]() they can be hard to come by - and is definitely a mod that requires regular maintenance. Doesn't do much for performance either. Might affect engine braking too... ![]()
#46 | ||
![]() ![]() ![]() ![]() Quote:
#47 | ||
#48 |
It is definetly to do with the valve timing. Higher revving engines are designed to produce more power by revving higher at the expense of lower down power. Higher revving (IL4 usually) have valve timings that overlap considerably. A lot of time both inlet and exhaust are open at the same time! Engines designed to produce power lower down the rev range irrespective of design will have far less valve 'overlap'. Hence your sucking against a closed space for most of the time and that slows you down better!
What do you think? |
#49 | |
#50 |
So what did I win then?
Engine Breaking? Hopefully not. Engine braking - is that OK? | butterick99 | SV Talk, Tuning & Tweaking | 14 | 12-09-09 10:31 PM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
Engine braking | Lakes_Puma | SV Talk, Tuning & Tweaking | 18 | 02-06-07 02:30 PM |
engine braking on the sv! | kwak zzr | SV Talk, Tuning & Tweaking | 11 | 25-04-06 12:01 PM |
Braking an engine | svrash | For Sale - SV's and SV related items | 1 | 22-03-06 10:43 AM |
