Old 03-04-06, 12:01 PM   #41
Peter Henry
Stew,,,They do cost a few bob don't they?
Old 03-04-06, 03:56 PM   #42
Balky001
Balky001's Avatar
Some interesting points and some techy stuff too! It remind me a bit of similar debates when ABS started becomong standard on cars - a good driver could outbrake an ABS system but then 99.9% of people couldn't, and the benefits in the wet or keeping stable were greater than the 2 feet a F1 racer may be able to stop the car in the dry (compared with the ABS system).
In practise, maybe a slipper clutch is an indulgance few will ever make use of but may talk about lots in the pub. But where some riders may like to feel if the back end is moving you are near the edge, well if you actually were, you'd feel it using a slipper too. If you are moving and you are not near the bikes limit is may be poor downchanging/clutch. I don't think a slipper changes the ultimate grip/lean of the bike. However, it keeps the suspension smooth, you get lots of engine braking if you set it up that way and whilst you may not use it on every corner or even every day, but when you do its does help on all surfaces and most speeds. It's also a big bonus for those that don't usually use the back brake. I have to agree with some others though, the blip and brake skill maybe be lost if slippers become standard on all vehicles.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 03-04-06, 06:08 PM   #43
SVGrandad
SVGrandad's Avatar
Default Can you get a slipper clutch for an SV?
Originally Posted by northwind
Hmm... have you got a pointer for where on the site that is? Looks interesting stuff.
Er yes. Try www.bankspower.com then click "Knowledge", then "banks Talks Tech - Main Page" then "Understanding Todays Diesel". It is about halfway down the article. Sorry about the long track!
SV1000S K4, Hugger, Scottoiler. Lowers
SVGrandad is offline   Reply With Quote
Old 04-04-06, 01:53 AM   #44
As far as i can tell from reading that, he's not referring to engine braking at all there, but to what he calls compression braking- loss of power through the compression stroke.
Old 04-04-06, 06:45 AM   #45
ophic
ophic's Avatar
Originally Posted by bankspower
The higher the effective compression ratio, the greater the pumping loss. The good news is, no matter whether the pumping losses are high or low, these losses are mostly recovered on the power cycle. That’s why there isn’t any “compression braking”, as we’ll explain next.
Seems to me they're actually saying "compression braking" is a bad term.
"Engine braking" usually refers to the overall braking effect of the engine & drivetrain, including frictional losses etc.
"Compression braking" usually refers to the specific component of engine braking caused by the pumping of the cylinders, which is usually the largest factor, and what varies between engine configurations etc. It's a bad term because the compression losses are recovered by rebound on the next stroke, and is actually caused by pulling a vacuum against a closed throttle on the intake stroke.
As diesels effectively have a permanently open throttle, they shouldn't have much engine braking at all. However everyone I've ever asked says that they do, so the theory goes out of the window at that point...
quick link to article: http://www.bankspower.com/Tech_todaysdiesel.cfm
PS I don't know anything at all about slipper clutches
Silver SV650SK3, Fuel exhaust
Sigma slipper clutch toadie For Sale - SV's and SV related items 1 21-06-08 07:35 PM
Sigma slipper clutch rich01483 For Sale - SV's and SV related items 13 11-02-08 10:26 PM
Slipper clutch? Stu Bikes - Talk & Issues 71 17-11-06 08:04 AM
Slipper clutch Brand New Bikes - Talk & Issues 4 01-07-05 08:47 PM
Slipper Clutch Peter Henry Bikes - Talk & Issues 8 17-06-05 08:01 AM
