#41 | |
![]() On the rare times I'm out with someone else, with them following, the conversations when we rest up tend to go something like this: Them: "Don't you ever brake when approaching a corner! I nearly ran up your **** a number of times cos your brake light never seems to come on and I'm faced with a sharp bend, you've slowed down and no warning!" Me: "Look ahead + correct gear = V-Twin engine braking & no brake light." I must add that I usually mutter under my breath "Try doing the first bit and you won't end up sitting on my tailpipe!" ![]() |
#42 | |||
#43 |
I wouldn't say I'm the most proficient rider, but I have to say I hardly ever use my brakes. I find the engine braing more than enough for most occasions, but then I never realy push that hard - at least I haven't for the last six months! The only time I rally use my brakes is for stopping at junctions! I just try to keep it in the right gear and keep it as smooth as possible.
#44 |
I would'nt advocate braking into corners except on a track and if you know what you are doing.The rule is get your braking and gear changing done and dusted in a straight line and then turn in to the apex.Power on to exit.If you must brake while turning then very gentle application is required,really little more than a steadying effect.The rationale is that a tyre only has so much grip, and this can be exploited as side or turning grip or fore and aft (braking or accelerating) grip.Use both at once and the tyre is rapidly overwhelmed.
Unless your name is Rossi.
#45 |
I have a major confidence problem on the corners too especialy after my bus incident......i just keep thinking the front wheel is gonna go from underneath me all the time and also metal covers scare the **** out of me to when im cornering too.....
#46 |
if i'm in mid corner and see a metal cover it puts a shiver down my spine too, the worst tho was when i was doing an island and i ran over a squashed drinks can with my front tyre, the front slid a tad and i filled my shorts! stay'd on tho.
Expansion Bottle overfill | metalmonkey | SV Talk, Tuning & Tweaking | 7 | 22-12-08 10:58 AM |
nos bottle and belly pan | socommk23 | Stuff Wanted | 5 | 20-04-07 01:50 PM |
Scottoiler bottle of oil - even empty! | Stu | Stuff Wanted | 9 | 06-02-07 10:25 PM |
where is your scottoiler bottle? | hovis | SV Talk, Tuning & Tweaking | 39 | 29-01-07 03:10 PM |
nos bottle | socommk23 | SV Talk, Tuning & Tweaking | 27 | 01-08-06 09:51 PM |
