Old 26-04-06, 08:03 PM   #41
Razor
The ZX9R and GSXR 6 pots are 90mm spacing, they won't fit on these brackets.
Old 26-04-06, 08:57 PM   #42
Not true, there's 2 different versions of the 6s, the ones that were on the SRAD 750 and the ones that were on the K1-K2 thou. The thou ones should fit- I've had a set on my Y-K2 750 forks.
Old 26-04-06, 09:00 PM   #43
Razor
Yes, they're the same as the GSX1400 calipers. We know
Old 26-04-06, 09:06 PM   #44
Right. So let me get this clear You know that the GSXR ones fit, and yet you say they don't?
Old 26-04-06, 09:14 PM   #45
Razor
The ZX9R calipers that fit GSXRs are 90mm, fact.
There are other 6 pots, but they won't fit on the ninja. I know this because when I broke my ninja I sold my calipers to a mate who used them on his GSXR1100. he had gold 6 pot nissan calipers form an early thou that didn't fit.
So obviously they wouldn't fit my crashed ninja either.
The newer ones are approx 64mm mounting holes I know this because I have them here.
Now tell me about all the other bikes you've had, must be a long list?
Old 26-04-06, 09:20 PM   #46
Eh, no, very short. All I'm doing is clarifying something you said that wasn't clear enough here, not getting into a contest about who's owned the most bikes
Your post said "The ZX9R and GSXR 6 pots are 90mm spacing, they won't fit on these brackets" which is true for some of the GSXR 6-pots but not for others. See? What you know doesn't matter if you pass it on wrong.
Old 26-04-06, 09:34 PM   #47
Carsick
Can I wave my willy as well?
Chill out Razor, this isn't a contest.
Old 27-04-06, 09:59 AM   #48
Razor
Default Re: RE
Originally Posted by HighSpeedAssault.com
In regard to SV-to-GSXR caliper conversion kit.
Our kit consists of machined steel adapter plates, machined (lathed) bushings, and hardware (nutes/bolts). NO other part other than the calipers are needed for installation.
00-02/750 and 01-03/600 GSXR calipers are the same.
In regard to warranty, these are for racing/racetrack applications so like any other aftermarket racing components, no warranty.
We will however, replace any defective parts no charge.
What this is, is a steel plate bolted to your GSXR calipers, it just moves the calipers rearward and inward for correct alignment with the stock SV discs.
The steel plates are stronger tham the cast aluminum fork legs they bolt to.
Comes with instructions.
Racetested in 2005, unbelieveable difference in stopping power and lever pressure.
Phone number for credit card orders is
636-922-2811
Ask for "HighSpeedAssault ordering"
We will also have our SV rearsets available soon.
Since most aftermarket rearsets don't elevate footpegs near high enough for racing, we will have our adpater-plates to give you 2.5" up and 2" rear adjustability. These will work in conjunction with oem or any aftermarket non-adjustable rearset.
We will have these on our website and available in under a month.
Hope this answers some questions.
Thanks!
http://www.HighSpeedAssault.com
Old 27-04-06, 11:23 AM   #49
21QUEST
21QUEST's Avatar
Default Re: RE
636-922-2811
Thanks!
Ben
Nemo me impune lacessit.
Old 27-04-06, 12:36 PM   #50
Can we stop this now please?
A public service announcement brought to you by your friendly, (mostly) neighbourhood moderator.
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Gsxr Brake disks sv_rory Stuff Wanted 9 04-02-09 05:23 PM
torque wrench - conversions skint Bikes - Talk & Issues 0 12-03-07 09:27 PM
GSXR 600 Brake Pedal? cb9002 SV Talk, Tuning & Tweaking 3 27-01-07 12:04 PM
Front End conversions Blue_SV650S SV Talk, Tuning & Tweaking 27 18-06-06 05:07 PM
