Old 15-08-18, 07:44 PM   #5441
Kenzie
Kenzie's Avatar
Does unpacking an OM10 to strip for parts count? It's getting there, there are some niggles to sort out with the house but otherwise good. Quite chuffed with the OM1, just need to run a test roll through. Might replace the prism in my other OM1 as it is showing signs of the same problem.
Old 15-08-18, 07:52 PM   #5442
yokohama
There's a small blemish at the bottom of the prism/viewfinder in mine too. Maybe I should check the foam and replace it to make sure it doesn't develop into a problem.
Old 15-08-18, 08:01 PM   #5443
Kenzie
Kenzie's Avatar
Yeah, you don't want that gunk getting into where it shouldn't be. It's like old light seals. If yours is blemished then it's already started and will need replacing.
Old 17-08-18, 02:54 PM   #5444
admin
John T
admin's Avatar
Cokin filters are universal. You buy the holder and then an adapter ring to suit the lens filter thread. I've a load in my hoard somewhere with various size rings. Useful to have.
Sent from my Nexus 7 using Tapatalk
Old 17-08-18, 05:26 PM   #5445
Kenzie
Kenzie's Avatar
I had to look up the 707, not seen one before. Looks like it was designed to rival the Minolta 7000. I have quite a few Cokin filters but I never use them.
Sent from my Xperia using Tapatalk
Old 18-08-18, 08:56 AM   #5446
Kenzie
Kenzie's Avatar
Buy one get one half price on film at Boots.
Old 18-08-18, 02:50 PM   #5447
Kenzie
Kenzie's Avatar
Going to do a feature wall in my camera room with this https://www.homebase.co.uk/superfres...lpaper_p405526
Old 18-08-18, 02:52 PM   #5448
admin
John T
admin's Avatar
Do you mean you're going to buy the paper or emulate it.
Old 18-08-18, 03:06 PM   #5449
Kenzie
Kenzie's Avatar
Buy the paper. Need to measure up the wall in question.
Old 18-08-18, 03:32 PM   #5450
admin
John T
admin's Avatar
Looks good. Do one wall with this and find a complementary tone to paint the other walls
