Old 12-10-15, 07:32 AM   #541
Swin
Swin's Avatar
Default Re: What have you tinkered with today?
Mirrors - although I should say it's more of a constant tinker process!
Fitted Chewy's extenders, fabulous item that I wish I had bought sooner, but I'm now in the "it's not quite right, fiddle fiddle" phase of getting my mirrors exactly how I want them, only to adjust too much and start the process all over again at the next set of lights
Riding a V-strom, well it has an Sv engine, don't it
Swin is offline   Reply With Quote
Old 12-10-15, 07:35 AM   #542
Niall_farley
Default What have you tinkered with today?
Stickered up my freshly painted nose fairing.... Talk about bum twitching nerves! Got it as near as makes no odds blob on.
Old 12-10-15, 04:35 PM   #543
Nutsinatin
Nutsinatin's Avatar
Changed the front bulbs and had a check of the alignment as I've noticed I can't see anything at night, horizontal was fine but vertical was 120mm from vertical marker, now 35mm below vertical marker so lets see if I can see anything tonight, cleaned the lenses as well.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 14-10-15, 05:25 PM   #544
AlexAdams
MotoSliders no cut frame sliders installed, I'm still not sure if all the washers are in the right place but it seems to fit properly!! Idle & TPS adjusted first time to about 1400rpm!!! Ran micro USB cable to front for phone holder, need the M24 x 1.5 locknut now.
Old 30-10-15, 06:50 PM   #545
AlexAdams
Am I the only one tinkering? M24 x 1.5 locknut sourced and phone holder installed into yoke. Clear indicator covers popped on. Digital voltmeter installed into dashboard to the left of the clocks, works brilliantly in the garage just a shame it's not really bright enough to read easily outside!!!
Old 30-10-15, 06:57 PM   #546
Trev B
Trev B's Avatar
Swin,sorry I don't know what chewy's mirror thingies are!!
Somewhere up north,Never regret something that once made you smile!!!
Trev B is offline   Reply With Quote
Old 30-10-15, 07:15 PM   #547
These are they, great upgrade
These are curvy ones, extends the base by about 20mm, which is enough to see past your elbows
Old 31-10-15, 05:16 PM   #548
SIII
SIII's Avatar
Took pipes off the Triumph America, polished them up with Autosol. Also started ACF50'ing it and ACF50 Corrosion Block grease on all the fasteners. Only 1200 miles on it, but previous eejit must have put it away wet.
Loads of chrome, so looks like I'll be spending most of the winter using a whole tube of Autosol to make her shine. Welcome to the world of cruising !!!
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 31-10-15, 06:30 PM   #549
Tube!? You mean 3 gallon pot surely
sent with all the fury of a clogged drain!!
Old 31-10-15, 07:38 PM   #550
Ratty
Ratty's Avatar
Changed the leaky 'Cup Seal' on the SV's clutch slave cylinder. There was some right cack in what was left of the old fluid when I popped out the piston.
Alan
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
