Old 22-02-22, 11:44 PM   #5731
Adam Ef
Adam Ef's Avatar
Default Re: Smile of the day - What is yours?
Test rode one of those very red bikes today. The morning looked like another storm, high winds and lashing rain. By the time I was out on the test ride the roads were bone dry, the wind had stopped and the sun was out. Not sure if the warm dry conditions coloured my view of the test ride, but it was definitely a fun bike.
Past:
Old 23-02-22, 08:54 AM   #5732
CheGuevara
This just returned from Nitron:
Although at the same time, there's a minor gripe in that it wasn't particularly cheap. With a new spring fit (they recommended I use 475lb rate) the rebuild came to £277 -so that added to the £300 I paid for it used. When I bought it, it had apparently already been freshly serviced by a well-known independent. Though as it turned out there was a loose bleed screw on the reservoir so it started leaking oil, which is what prompted me to send it off to Nitron to get put right.
Anyhow that's done and I can start putting things back together.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 23-02-22, 09:23 AM   #5733
Adam Ef
Adam Ef's Avatar
Nitron do a brilliant job. Not cheap, but worth it for the quality and service.
Past:
Old 23-02-22, 09:25 AM   #5734
Adam Ef
Adam Ef's Avatar
They also often have good history records of shocks they've sold. I was able to take my VFR one in and get a full history of the shim stack adjustments, valving changes, spring rate advice and what sort of rider and riding it was originally specced for. It's a good ride out to drop off and collect with some great roads around Oxfordshire on a sunny day.
Past:
Old 23-02-22, 09:46 AM   #5735
CheGuevara
I didn't ask for the history, but it became apparent in conversation that they had details on this shock.
And agreed - I think it was money well spent sending it directly to Nitron.
Old 23-02-22, 10:00 AM   #5736
Luckypants
Luckypants's Avatar
Adam - did you fit the VFR shock? Worth it? If you have pictures would appreciate them via DM on here. I'd really like to sort my bike out and use it this year....
Old 23-02-22, 01:12 PM   #5737
embee
embee's Avatar
I have a Nitron R1 on my NC700. Excellent products if a little pricey, but you soon forget the cost
Old 23-02-22, 07:32 PM   #5738
Adam Ef
Adam Ef's Avatar
I'm actually selling the shock as I had to let the bike go a few months back. I did fit remove and refit and then remove the shock again. It's the one with the remote compression canister and the remote preload, so a lot of bits to thread through, and included jacking up and lowering the swingarm repeatedly to weave all the parts through in different stages. It was quite a process. Worth it though as the Nitron shock and uprated Ktech front springs made it feel like such a sharp bike. Still plush but very accurate at the same time.
Past:
Old 23-02-22, 07:32 PM   #5739
Adam Ef
Adam Ef's Avatar
It's on evilbay... https://www.ebay.co.uk/itm/194783543517
Past:
Old 26-02-22, 05:26 PM   #5740
DJ123
DJ123's Avatar
New Bike day has arrived, and i'm a very happy boy indeed.
Also very fortunate the weather is decent enough to ride this weekend too, and put some miles on it.
BMW F800ST
what made me smile kiggles Idle Banter 1 07-04-11 09:00 PM
Smile :o) Speedy Claire Idle Banter 5 07-10-10 08:21 AM
To make you smile gruntygiggles Idle Banter 7 03-06-10 12:45 PM
Smile... the_lone_wolf 2009 Annual Rideout 14 31-07-09 01:01 AM
First smile kitkat Photos 12 08-02-09 08:55 PM
