Old 19-12-08, 09:21 AM   #51
Ceri JC
Default Re: Does jacking the back up work
Originally Posted by zadar View Post
funny,most better handling bikes have them stock from factory
Is it not possible that part of the reason these (generally higher cost) higher spec machines have them is that it makes them look "trick" and closer to race spec machines, which in turn sells more bikes? Perhaps an analogy would be a slipper clutch- they're becoming ever more prevalent on the latest sports bikes, yet it's questionable how necessary they are for most road riders. What proportion of their appeal (for most riders, I know you're a bit different ) comes from the practical use of it, versus the bragging rights?
As to the SV needing one, I've only had one tank slapper (by which I mean the bars slamming from full lock to full lock, with enough force to dent the lock stops) on the SV and that was when my front wheel hit a deer. I've had the bars "wag" cornering over bumps at speed, but improving the suspension has all but eliminated this. I have seen some people confuse bars wagging with tank slappers, been overly worried about it and "fixed" the problem by buying a steering damper before properly sorting the suspension out. I think this is what DD is talking about.
Old 19-12-08, 10:21 AM   #52
zadar
no,it is not to look trick.it is safety part.
regardless how you ride or how you set your suspension you can run in situation where damper helps.and that is reason it is on bike.
saying it masks bad suspension set up makes no sense.you set up suspension for what you use bike.there is no one set up that works for all riders and all uses.
and it does not have to do anything with set up.many times rider itself makes tank slapper.
Old 19-12-08, 10:21 AM   #53
stuballs
tbh my main reason for fitting a damper to my bikes is the extra stability and "safety cushion" they give you when stunting. Ever landed the front wheel slightly off centre after a high speed mono? The steeper the front forks the worse it is if you mess up the landing. same for stoppies (though steering rake makes no difference).
As for modern bikes having trick equipment as standard I suspect it's a combination of marketing and being able to use the trick bits in superstock (they can't fit a slipper clutch if it's not standard equipment)
I'd say we're not well and truly off topic! Sorry
Old 19-12-08, 11:27 AM   #54
Dangerous Dave
The Honda Fireblade had the MotoGP evolution one fitted for years, and yet Honda will tell you it doesn't need a damper and along with the fact that the race teams didn't use it was proof enough.
Old 19-12-08, 11:29 AM   #55
Dangerous Dave
Answered you own point there, the fact is a mass produced bike cannot be set up to suit every rider from the factory.
Old 19-12-08, 01:05 PM   #56
DarrenChay
"Somewhat corpulent" Tactfully put!
Preload is set 1 from top (although I understand jacking the back up increases preload slightly for any given setting?)
Fork springs will need doing, particularly after reading up more on here, as i'm around 18st so even more weight over the front end.
I originally thought the requirement for sorting the front end wouldnt matter so much to me, as I dont exactly take the bike to anything approaching its limits (cos i'm still carp!)
I think I'll leave the replacement dog bones off for now, untill I fit some uprated fork springs.
Originally Posted by johnnyrod View Post
Darren, it's only an inch or so really. If it's looks you're after then "invest" in a different bit of plastic for the back end. You won't like it when it rains though. Have you got the preload and spring weight right, if you're somewhat corpulent?
Old 19-12-08, 02:12 PM   #57
haha i think we must be the only ones to know what a full tank slapper on an SV feels like....I urge everybody to hit a deer...lol
In that I mean, its a rarety to get a tank slap on an SV and you have to do something pretty spectacular to get one.
Steering damper needed on an SV? what a crock o dogs.....
Old 20-12-08, 08:20 AM   #58
zadar
exactly.and when I set up bike to suit me it needs damper.
there is nothing wrong with my suspension set up
Old 20-12-08, 01:35 PM   #59
I lock-to-locked mine once. But it took an AWFUL lot of incomeptence when "setting up" my rear shock So much rebound damping that it packed down massively over a load of bumps then started kicking the front instead of soaking them up. Scarier than actually crashing, that. Luckily it turned out that the perfect response was to freeze in terror and do nothing.
Stock SVs certainly don't need a damper. That's an easy question. Other SVs, not so easy. Depends on build and use. Like, if you rode only at Knockhill, which is now fantastically smooth, then that'd let you away with a lot more than if you rode only at East Fortune, which is like a potato field with a skin of tarmac over it...
Yippee the wife may be going back to work timwilky Idle Banter 17 13-02-09 09:03 PM
first day back at work after AR08 Quiff Wichard Photos 34 10-07-08 09:37 AM
Back to work pmapp Idle Banter 37 03-01-08 10:40 AM
Mrs Ape back to work. Stig Idle Banter 41 21-05-06 09:35 PM
*Groan* Back to work tomorrow... Ping The Essex Lounge 9 26-07-05 09:39 AM
