Old 15-12-09, 10:25 AM   #51
fastdruid
fastdruid's Avatar
Default Re: Damaged piston (VFR400)
Originally Posted by Spanner Man View Post
NC30's have pretty tough engines. However, as the valve shimming procedure is pretty fiddly most garages don't bother doing it. So it is possible to burn a valve.
+1 it is a PITA to do[1] and normally when checked they are fine...
It does make quite difference to starting and running though to have them spot on.
Also balancing the carbs makes a difference and again is a royal pita to do.
Druid
[1] Although doesn't need cams out like the SV as its shim over bucket.
Old 15-12-09, 10:26 AM   #52
EssexDave
I didn't think about the compression test.
That would be why there is no compression if it's not turning over :S
I really don't think I should let them keep my bike.
They want to charge me £50 to tell me i need a new piston..
Old 15-12-09, 10:36 AM   #53
Dave I think they're pulling your p*sser.
Turn it off of the crank? I have no idea how you do a compression test though to be fair
You screw the tester into a plug-hole, hold the throttle wide open and crank it.
Old 15-12-09, 10:37 AM   #54
Alpinestarhero
Dave, get your bike back off them, they sound a bit un-clever TBH. Can you get your bike to spannerman? I know he has a fair bit of experiance with those little V4's.
good luck, i hope the engine is ok and its something simpler, keep us updated
Old 15-12-09, 03:29 PM   #55
EssexDave
Apparently the engine is turning over. :s
Old 16-12-09, 08:19 AM   #56
Sudoxe
Really? From reading the thread, I thought it was you that was being turned over.
Dan
Old 16-12-09, 12:16 PM   #57
So they charged the battery and ran a compression test. Ask for what the values were on all pots. And if they had the throttle open when they ran test
Old 16-12-09, 12:25 PM   #58
beabert
Battery directly to the starter, if it has starting issues.
Need to do it twice if low with and without oil in the bore, as above throttle must be fully open.
Old 16-12-09, 03:32 PM   #59
EssexDave
How hard is it to rebuild an engine given unlimited time and funds?
Old 16-12-09, 03:39 PM   #60
Alpinestarhero
good call, you wouldnt expect there to be no compression on any of the 4 cylinders, unless you had just the most aweful luck in the world
For Sale: VFR400 NC30 EssexDave For Sale - Other Bikes and General biking items 2 13-10-09 08:10 AM
VFR400 breather hose EssexDave Bikes - Talk & Issues 5 22-09-09 08:28 PM
Honda NC30 VFR400 BigFootIsBlurry Bikes - Talk & Issues 12 30-04-09 12:35 AM
FOR SALE - VFR400 NC24 D Reg geodudeft For Sale - Other Bikes and General biking items 2 10-04-09 05:25 PM
Honda VFR400 arc123 Bikes - Talk & Issues 12 20-04-05 11:24 AM
