#6621 |
Fiver! I've seen a few of those around lately but all for serious money. Nice
#6622 |
Well, £5.60 if you want to be extact plus post. 153708383749 its rough but I think it will be useable if I can get the shutter running right. Trying not to post up any cameras but 362810842069
Sent from my Xperia using Tapatalk
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 15-11-19 at 09:28 PM. |
#6623 |
I'm trying not to buy anything! So far going the right way, another cheap Tokina zoom sold today.
#6624 |
I'm trying and failing. Want a Contax D but will have to settle for a Pentacon FM instead.
#6625 |
Started tearing into the EM. Glue everywhere and the thing that actuates the shutter blades seems sticky.
![]() ![]() Sent from my Xperia using Tapatalk
#6626 |
I don't really want to but I think I'm going to have to remove and split the Yashica Mat shutter. I've tried flushing it but it keeps gumming up again. If it's going to be done properly, either that or get the shutter off, remove the glass and soak the whole lot. I think option one will be better in the long run.
Flickr https://www.flickr.com/photos/39887875@N06/ Last edited by Kenzie; 19-11-19 at 09:53 PM. |
#6627 |
Definitely
#6628 |
Don't worry, I won't be sending it your way!
#6629 |
I've been working on the Bessa, it has a Compur Rapid shutter, so really all you need is one not-very-small screwdriver. Al fine but now it's back together it's sticking at slow speeds. Might be the adjustment of the escapement, the hairspring tension, or that it hasn't got enough oil. Will have to have another look tomorrow. Also looked at the other Contessamat, the flash sync isn't firing, wire is connected to the hot shoe. Lenses need a clean but otherwise it works. Grrr.
#6630 |
There are so many versions of the Bessa it's hard to keep up. I've got the lens board off the EM, luckily it was only four screws and lift it off. Just need to get the shutter off and cleaned up. I could do with making a 6x6 ground glass to check the focus. If I got the glass from a photo frame, how could I etch one side?
