Old 30-06-08, 07:48 PM   #61
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Default Re: HID lighting
righto, got all the bits i need to wire the beast, taking tomorrow off work to look after me mam and get this done, but i have one question left un-answered...
can i short the starter button so when it's pushed the power to the lights ISN'T cut? or will the extra drain on the battery cause starting problems?
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-06-08, 09:53 PM   #62
Why bother?
Old 30-06-08, 10:14 PM   #63
the_lone_wolf
Captain Awesome
Why bother?
as explained earlier, the starter button doesn't just connect the starter motor circuit, it also cuts the headlamp circuit, fine with halogens as they just dim and come back, but HIDs apparently shouldn't be switched on/off quickly like that as it's not good for the ballasts
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-06-08, 10:16 PM   #64
Ah right must have missed that post sorry...
Presuming there's a headlamp relay just chop the wire from the starter button, I'll just have a look in haynes and figure it out.
Edit: what bike are we on about here?
Old 30-06-08, 10:19 PM   #65
the_lone_wolf
Captain Awesome
European K5 S model
looking at the wiring diagram in the back of my haynes there is no headlamp relay, the circuit runs straight through the switch to the bulbs (probably why it only has a 15A fuse...) it seems the easiest way would be to just short the headlamp wires from the starter button...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-06-08, 10:25 PM   #66
Yeah looks like it, forgot there was no actual light switch on a pointy.
Leave a tail on the connector if you cut the wires so the procedure can be reversed if needs be.
HID draws about 35W so I doubt this will be a problem if your battery is healthy
Old 30-06-08, 10:32 PM   #67
the_lone_wolf
Captain Awesome
70W with two ballasts
but yeah, that's still less than two 55W bulbs. and the high current draw (the reason for the relay in the first place) is only present as the ballasts "gear up" whilst initiating and stabilizing the arc, i always wait for the fuel system to prime before starting the bike, so that habit should help keep the two higher current applications separate
so far i've designed the new harness for the HIDs to be completely removable without cutting/splicing any of thr stock wiring, but i reckon i'll have to come up with something more complex to not do it to the starter button...
pictures to follow tomorrow if i can be arsed to take any...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 30-06-08, 10:35 PM   #68
Take the pins out of the connector and wrap them in copper wire then heat shrink over the top of them? A weak spot but very easy to put back to standard.
Old 01-07-08, 07:00 PM   #69
the_lone_wolf
Captain Awesome
some pictures from today, due to not having a couple of things it took most of the day, but i'm happy with the result
my new HID loom (because i wanted the relays under the seat with the others...
where i eventually put the ballasts after about 90 mins of staring at the bike (other one on other side...)
sorry there's nothing better, it was hot and i wanted to get it done...
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 02-07-08, 11:21 AM   #70
Whoa that's some neat wiring.
import mot lighting the g SV Talk, Tuning & Tweaking 2 24-03-09 07:36 PM
Aux lighting. rictus01 Bikes - Talk & Issues 3 13-02-09 02:08 PM
Lighting Issue Crash_Artist Bikes - Talk & Issues 6 07-11-08 08:20 PM
HID lighting erics02 Bikes - Talk & Issues 28 26-10-08 08:33 PM
lighting up your bike richbeales SV Talk, Tuning & Tweaking 32 25-10-07 05:56 PM
