#61 | |
![]() i too am happy to come and lift/hold/fetch/carry things for you mark, if only to try and be helpful and learn a bit about engines!
AR08 to AR13-QUALITY! 650s: '52 curvy in yellow, was my baby ![]() cbr600rr: Mivv exhaust and a bagster tank cover. Now gone to a new home. Daytona 675: Arrow can (with a baffle that's gone missing in action.... ![]() ![]() |
#62 |
for thoughs that wish to know.
edited for stu this is the righthand side of the engine (sitting on the bike). (1) Balancer shaft (in front of the barrel) (2) Main crankshaft (3) oil pump (4) transfer shaft (transfers drive to the oil pump from the crank) (5) Gear selector cam ( gives the different gear positions) (6) gear lever output shaft (other end connects to the foot change) (7) Clutch main shaft ( ![]() (9) main gearbox shaft (10) cam chain HTH Cheers Mark.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! Last edited by rictus01; 27-02-09 at 05:46 PM. |
#63 |
You setting the rest as homework?
#64 |
No that's the "can anyone tell me what these left over bits are for.........."
#65 |
Trinity
#66 | |
#67 |
Trinity
#68 |
#69 |
Trinity
Mark says he hasn't got it anymore, so I'll do it on Monday as I had printed it out already.
Paul It wasn't a new pic it was just ![]() with (1) Balancer shaft (in front of the barrel) (2) Main crankshaft (3) oil pump (4) transfer shaft (transfers drive to the oil pump from the crank) (5) Gear selector cam ( gives the different gear positions) (6) gear lever output shaft (other end connects to the foot change) (7) Clutch main shaft ( ![]() (9) main gearbox shaft (10) cam chain all identified Last edited by Stu; 01-03-09 at 12:41 AM. |
#70 |
well the thing with the CCM guy to get a crank, seems not to have happened and I don't want to waste anymore time, so order a secondhand one today, hopefuly be here for the weekend.
Cheers Mark.
