#61 |
I lay on the floor under Mike`s bike to get at one of those rusty buggerin seized nuts and saw the "Chamfer" he had put on the exhaust and said "F***in Hell Mike" ...... It was proper ground down , there must have been a fireworks display for the people behind him
#62 | |
![]() There was no pressure in that hydraulic pre-load adjuster, no fluid came out of the banjo when I took it off and it looks like there has been damping fluid getting past the piston rod seal. That shock is FUBAR, not up to going two up on Welsh roads I reckon. |
#63 |
Well it did seem a bit wafty when you adjusted it , there was jack all halfway down the Marker lines on it anyway , Cricket bat , point to the Horizon , toss reservoir in the air and PUNT it .
#64 |
What I want to know is how the new shock got scratched
#65 |
I took it for spin and found it leans right over now......
![]() It's a tight fit to get it in and a bit of wiggling was needed to get it all lined up... Most of the marks is oily hands though....
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 ![]() Snow Plough Appreciation Society - Member #3 ![]() Last edited by Luckypants; 15-04-09 at 08:28 AM. |
#66 |
Took it for a spin with no pipes on ?
#67 |
#68 |
Having a shock that colour is deffo a bit 'secret weapon'
#69 |
#70 |
Glad it`s all done... will be the dogs ******** now
Catherine Wheel Final Whos Coming and "Other Bits" Thread - PLEASE READ IF YOUR COMING :-) | 454697819 | Pennine Massive | 61 | 12-10-08 10:09 AM |
AR 08 are you coming ? | stewie | 2008 Annual Rideout | 174 | 03-07-08 07:33 PM |
Coming out | DanAbnormal | Idle Banter | 12 | 20-04-08 11:40 AM |
No ones coming! | DoubleD | Idle Banter | 16 | 12-05-07 05:14 PM |
Coming soon.......... | Daphne | Idle Banter | 31 | 21-04-06 09:45 AM |
