Old 11-05-09, 11:15 PM   #61
Default Re: USD GSXR1000 k1 forks | standed forks - curvy
Speedo sensor, Cherry switch GS100701, home made bracket
Cost £29.27 RS Components
Originally Posted by Nicky S View Post
were all you have done is told me ant ya i ment a link to a site or something
http://lmgtfy.com/?q=rs+components
Old 11-05-09, 11:19 PM   #62
Nicky S
Nicky S's Avatar
dont undertsnad this bit ... Sensor; 15-32 in.-32; Sink; 4.5 to 24 VDC; 6 mA (Max.); 400 mV (Max.); 1 in.
will i need magnets as well or do they come with the sensor ?
http://uk.rs-online.com/web/search/s...00701&x=2&y=19
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 11-05-09, 11:23 PM   #63
That is spec of sensor.
You need magnets also.
Bibios choice is OK but I found it better to use some countersunk magnets off eBay, that way they can simply be bolted through the disc rivets with some M4 bolts and nylocs. Totally secure and swappable between discs.
Old 11-05-09, 11:33 PM   #64
Nicky S
Nicky S's Avatar
have you got a picture of this ???
write so after are long thread which is full of info is my list below right ?
GSXR1000 K1 Bits
* USD Forks
* Callipers + Bolts
* Mud Guard
SRAD Bits
* Top Yoke
* Top Yoke Nut (51353-27C40)
* Top Yoke Washer (51356-29E00)
* Adjuster Nut x2 (51631-33E00)
* Adjuster Washer To Suit x1 (51631-33E00)
* Bottom Yoke
* Spindle
* Wheel
* Discs
Other bits needed
* TWF Bearing (Clicky For Link)
* Parts To Make Speedo (Clicky For Link) + Magnets
Old 11-05-09, 11:37 PM   #65
OK
move the discs to the SRAD bits section (the 0.5mm offset we were jabbering about earlier!) (bolts it doesn't matter, they are same)
Add; SRAD adjuster nuts x2 and adjuster washer. (Will find you some suzuki part numbers in a bit)
Old 11-05-09, 11:42 PM   #66
Nicky S
Nicky S's Avatar
OK
cheers YC
my list ok yer ....
quick question which i didnt think about what about the speedo and headlight ?
also am i being stupid but arnt these the same part ?
* Top Yoke Nut And Washer
* Adjuster Nuts x2 And Adjuster Washer
Old 11-05-09, 11:53 PM   #67
No they are not.
The top yoke nut goes above the top yoke.
The adjuster nuts go below the top yoke with the adjusters washer between them... for the purpose of adjusting the head bearings.
Of course if these were not there, and you simply tightened the top yoke nut and clamped the bearings rigidly with the full torque of assembly. The bearings would be preloaded so much that damage would be inevitable.
Old 12-05-09, 12:03 AM   #68
Nicky S
Nicky S's Avatar
No they are not.
ahhhhhhhh i see YC your a clever guy
you got any pictures of your front end ??
also how will i get over the problem of mounting the gauges and headlight ?
Old 12-05-09, 12:06 AM   #69
Headlight, you can get some universal headlight clamps, they're fairly common for streetfightery type bikes.
Clocks, I filled the back of the top yoke with fibreglass and drilled and tapped that. Bodgetastic, but it worked temporarily.... and is still there now!
Old 12-05-09, 12:15 AM   #70
Nicky S
Nicky S's Avatar
bodge dosent sound lik a YC job lol
ill have to have more of a look at it when i have all the bits i need and start doing it.
can i see a picture if you have one of the magnets for the speedo ?
any part numbers for them bits ?
curvy forks husky03 For Sale - SV's and SV related items 5 29-10-08 07:10 PM
Curvy forks wanted. skapegoat Stuff Wanted 1 22-01-08 07:29 AM
Gsxr Forks On Curvy CHICKENSTRIPS SV Talk, Tuning & Tweaking 1 18-07-07 05:45 PM
curvy sv forks fit k4 ??? daddy_sperm SV Talk, Tuning & Tweaking 2 24-04-05 07:12 PM
Conversion to GSXR1000 front forks ? Powergaard SV Talk, Tuning & Tweaking 2 21-01-05 12:12 PM
