Old 08-07-09, 06:18 PM   #61
christopher
christopher's Avatar
Default Re: 33bhp Dyno Resutls
This is all based on the assumption the bike will sit @ 33bhp for 2 years as well...
christopher is offline   Reply With Quote
Old 08-07-09, 06:30 PM   #62
hindle8907
hindle8907's Avatar
does thrashing a bike all the time mess it up . or are they made to be hammerd ?
Old 08-07-09, 07:55 PM   #63
Bluefish
don't know not got mine past 144
Old 08-07-09, 09:02 PM   #64
boot
All the time possibly, but according to Suzuki themselves, even with a new bike, you should thrash it like a ba5tard regularly. Just make sure you're reasonably diligent with maintenance.
Incidentally, Carol Nash didn't require a cert from me. I read extensively at the time of restricting my bike, had the washers (curvy) made locally and haven't had it tested. I figure, if its a write-off they won't be able to test it, but I could prove the washers are in there. Had been told buy chap at Suzuki Chesterfield that power should be measured at the crank.
Old 08-07-09, 09:11 PM   #65
Originally Posted by Milky Bar Kid View Post
WRONG WRONG WRONG!!
If you pass ANY document that you know to be false and gain something from it (ie. heaven forbid, you prang the bike, send the falsified cert off to insurer and they pay out - fraud. Or worse still, insurers have cottoned onto said ake certs and you send it to them and they go "PING" pass it to Police, refused to pay out adn you are booked with attempted fraud.)
But anyway, why go with insurers that wasnt a cert if u bin it anyway, most of them don't these days.
Actually you would be passing on a document you knew to be true, 'cos it IS restricted. So what are they going to do, check for the restrictor present and correct and find no offence commited?
I'd say go with an insurer who's going to be reasonable about it.
Boot. The guy who told you power measured at the crank is either a liar, or illiterate.
DVLA literature clearly states "net" power output.
Bikes are made to be thrashed.
Old 08-07-09, 09:30 PM   #66
V-twin
My restriction kit from the manufacturer is only valid with the bike in standard trim, that includes exhaust, carbs and air filter. I had it dynoed at christmas as the bike was stalling alot and the reading came out at 25bhp!!!
The powers that be will stick to the offical line and say it has to be 33bhp for two years unless you are over 21 and can do an accelerated access course - does that course still exist?
Old 09-07-09, 07:43 AM   #67
hindle8907
hindle8907's Avatar
through every gear ? lol
lol
Old 09-07-09, 07:52 AM   #68
ThEGr33k
Im a little late to this but Chris has already said what you need to do... You need to get them to change correction factor to SAE. Oh and put RPM on the bottom not the damn speed.
Or even better, go back to the place with a Flash pen (memory stick) and ask them to put the run file on there and ill have a look at it and set all of the above. Its likely that the guy running the Dyno wont know what your on about when you ask what I mention. Sigh. Knock on wood?
Interesting Curve, its what I expected. I guess the Air/fuel must be kept about right by the ECU run 2nd set of butterflies...
Take care.
Old 09-07-09, 07:53 AM   #69
ThEGr33k
They are made to be thrashed. Just make sure you change the oil on it as often as you should and you shouldnt have an issue.
Old 09-07-09, 08:07 AM   #70
keith_d
keith_d's Avatar
Hmmm..... I'd go and have a chat with the guy in the local bike shop. For a fairly nominal payment they could issue a certificate confirming that a 33BHP restrictor has been installed, including the Suzuki part number and serial number (if any).
Keith.
33bhp restriction - Dyno chart? SVeeedy Gonzales SV Talk, Tuning & Tweaking 8 04-06-10 02:32 PM
Dyno Roo Star Pennine Massive 11 04-07-09 02:32 PM
have you had yours on the dyno mac650s SV Talk, Tuning & Tweaking 11 12-12-05 02:49 PM
have you had yours on the dyno imaleon Bikes - Talk & Issues 10 06-01-70 05:29 AM
