#61 |
Nitron sport:
worth every penny. bolted on and haven't touched a singe thing and its blisssssss. its that good its showing up the GSXR 600/750 k4-5 front end. its silky smooth and soaks up all but the most horrendous bumps. now where can i get a valve kit for my front end to match the shocky ![]() |
#62 |
icanopit - I was wondering if the aftermarket bottom mount can be used to extend vitually any shock to the desired lenght. I have a k8sport and despratley want to upgrad the rear shock but i want to do this without the need for adjusting the battery box etc.
Does the adjustable lower mount mean i van purchase any gsxr k8 rear shock and use the mount to bring it up to the correct height without compromising integrity of the rear suspension. Maybe YC can comment - please!!! |
#63 |
The shock extension just makes the shock longer at the dogbone end. You'd still have to cut the battery box.
#64 | |
That - Right there. Nitron Sport. |
#65 |
what about if you went for a shock with a 90deg resevior?
#66 |
#67 |
#68 |
i might be wrong but im sure that their are shocks which would fit without cutting the box but they are either too short or too stiff. if they are too short then surely the bottem atachment is the answer.
Im going to trail through some of the old posts to find exactly which ones dont need chopping! help! |
#69 |
Re: Which GSXR shock suits K8?
-------------------------------------------------------------------------------- Quote: Originally Posted by badsaboy do we know of any shocks bar the expensive ohlins etc which do not require the battery box to be cut? On a pointy the ZZR14 and 06-07 ZX10R shocks simply need a small plastic part unscrewed from the toolbox/battery box to fit. Completely reversible if for some odd reason you wanted to fit the original etc. ZZR shock will probably have too high a spring rate unless you have a pie retention problem Sadly you don't find many ZX10R shocks (of the right year) going cheap on eBay etc. |
#70 | |
SV650 K6 shock & GSXR1000 K4 Shock | weecorey | For Sale - SV's and SV related items | 0 | 03-05-09 08:02 PM |
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? | Paul the 6th | SV Talk, Tuning & Tweaking | 37 | 31-10-08 12:26 AM |
M10 55mm Shock bolt and nut for Kwak Shock | Mr Speirs | Stuff Wanted | 3 | 24-10-08 12:00 AM |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) | alien19779 | For Sale - SV's and SV related items | 0 | 28-03-06 01:16 PM |
