Old 30-03-06, 08:40 PM   #61
Out of curiosity, are you using mild or stainless wire for the welding?
Old 30-03-06, 08:45 PM   #62
-pATz-
Hi guys!
Ok, went to the garage this evening. Had 5 litres of fresh gasoline and thought "now please start". Emptied the tank from the (supposed) bad fuel and held the flag high until everything once again set to be the perfect moment and hear the bike for moaning for the first time with them Duc pipes installed...
Almost sh*t myself (sorry) of anger and frustration when it once again didn't start. Thought about auctioning the bike several times... "Selling her that didn't start"...
OK, thank God I didn't. Decided to once again go throught the electrics on the bike and found the problem. You know, I have all the cables hanging down since don't have the undertray fitted... this meant that the automatic ignition stop switch was on (when bike fall to the side it cuts the power), what's the name for it? Problem was easily solved when I just lifted the switch in up right position!!!!!!!!
I realized I have a much more advanced bike because I had no knowledge of this switch existing...
IT STARTED!!! Do you think it sounded nice??!! Now this was where I went flying off to heaven and the moon! It sounds a lot like my former VTR 1000 Firestorm with em carbon high MIVV's... although lika a little sisteer to the VTR... not that aggresive.
I reccon I'll get problems with fitting the battery and I might need to go for a gel one... absolutely have to cut the original undertray (nice I've bought a used one in spare...).
Aaaaah, Can go to sleep with the flag high tonight.
Cheers!
Old 30-03-06, 08:49 PM   #63
-pATz-
Hi Northwind! No doubt using stainless in the MIG... wouldn't wanna get rusty weldings and finally the piping falling to bits...
Old 02-04-06, 12:17 PM   #64
glade
glade's Avatar
It looks brilliant!!!
How much clearance is there between the swingarm and the pipe? Looks close!!
glade is offline   Reply With Quote
Old 03-04-06, 08:29 AM   #65
-pATz-
Hi glade!
It's not that close as it might seem on the pictures. I've taken into consideration the swinging of the swingarm... surely need to see if this will be a problem when rifing the bike...
What I'll do with the brake hose on the swingarm is still open as the original hose comes to near the pipe. Think I need to install some stainless steel brake hose of some sort. Anybody have other suggestions?
Old 03-04-06, 09:39 AM   #66
Peter Henry
pATz...That is looking very good indeed! Well done. I think you might have to figure out how to attach some kind of heat shield to the link pipes as they are going to be very close to your legs when you are riding. They will cook you. Have a look at how they do it on the 749/999's for your inspiration. Basically you need a couple of spacers welding to the pipe and then some kind of plate fixing to them. An air gap in between the pipe and the shield will mean ess heat in itself.
You could even weld a couple of nuts at the right kind of spacing to accomadate all manner of heat shields that are available on the internet.
Old 04-04-06, 04:25 PM   #67
-pATz-
Hi Peter Henry! Gracias for your comments!
Think I'll do just as you suggested with the heat shield and lucky I am having spare parts of that 748/916 piping... just some easy cutting and welding.
Sheit, it's still a lot to do before season (= 1 month time)...
Cheerio!
Old 04-04-06, 10:21 PM   #68
Black Rider
Hey looks like it's coming along well!!!!
I was looking in the gallery and found these pics! :P :P :P
Just for anyone out there who fancies doing the 916 thing - you don't have to get rid of the lights and it can still look cool!
Here's one of the heat protector too!
http://www.sv650.org/gallery/pic31/index.htm - there's the link - the pics are right at the bottom
Ok they're not quite under-seat but they still look AMAZING :P
There weren't any of the battery position
I'm sure you'll figure something out!
Well done mate! Hope it's ready in time for the first bit of nice weather over there
Old 06-04-06, 04:44 PM   #69
-pATz-
Hi Need2BuyAnSV650S!
Nice comments and nice pics you've put up here. Actually I thought at first about buying some ready made high-up slipons of some fabric preferably incarbon. However scrolled the internet and found this project and got inspired myself! I then gave it a thought and started dreaming... this was around the new year. Funny how things turn out when you start dreaming and realizing that the project might turn up nice... it seems nice as it's now!
Thanks for the tip about the protector. Will keep this in mind when placing/welding the protectors (will need several!?)...
Cheers!
Old 06-04-06, 04:59 PM   #70
Mmm, I like the pipework on that one but I think the cans look pretty awful tbh. Far too wide. If they'd been vertical, or round cans, it'd look far better.
GSX1400 Exhaust cans Stig Photos 13 26-02-09 09:00 PM
exhaust cans re wrapped gaz-sv650s SV Talk, Tuning & Tweaking 6 21-08-08 07:20 PM
Exhaust End Cans - What ones fit on the SV from other bikes? thefallenangel SV Talk, Tuning & Tweaking 5 14-05-08 09:13 PM
SV1000S Exhaust Cans Wanted GSX1400 Stuff Wanted 4 12-11-07 05:00 PM
Exhaust cans in America AlfBoy Exhausts 4 13-09-04 01:12 PM
