Old 09-06-06, 09:18 AM   #61
Flamin_Squirrel
Got some GSX-R brakes, just need the brackets now
Old 09-06-06, 01:17 PM   #62
Razor
I've got a set, not fitting them as selling the SV.
PM me if interested, I've got the calipers and a set of HEL braided hoses with all the banjos and washers if needed.
Old 14-06-06, 06:04 PM   #63
Flamin_Squirrel
Well I've just discovered that there's an extra lug on the pointy for a speedo cable retaining bolt. Ergo, they wont fit on an SV650 K3 or onwards.
Well, I'm ****ed off.
Old 14-06-06, 06:52 PM   #64
Khewett
Well, I'm p*ssed off.
Cut it off with a dremel.
If you need to reattach at a lter date use some JB Weld paste which will hold it.
Its not a load bearing bolt hole and only holds a cable flat. You could cut it neatly to allow you to use caliper adaptors, and so when re attched with OEM calipers no-one would now.
Old 24-06-06, 07:23 PM   #65
Knaapie
Would SRAD brake calipers work as well? I'm having a hard time to find some good 01-03 GSX-R calipers, but I did find some SRAD calipers. I know that the mounting points are 90mm apart from eachother instead of 62mm.
Old 24-06-06, 07:53 PM   #66
r4ce_e3nd
If you make them yourself: YES
I bought some of a CBR600 K3 and will (try) to make them myself, if I have time...
Old 24-06-06, 08:48 PM   #67
Knaapie
Ok, thanks! So you've got some black Nissin calipers? Or did you buy the gold ones from a RR?
Old 24-06-06, 09:07 PM   #68
mart
[/quote]
They are, but the standard forks can't even deal with the standard 2-pots. The limiting factor on a standard SV's brakes is the suspension, not the brakes, IMO- the excessive dive and braking instability reduces the bike's ability to use the braking power. But with an appropriately sprung and damped front end, it'll be different.
(though then I'd like to point out that the cost of rebuilding a standard SV front end to a decent quality, and then these brackets, and the calipers, will most likely be more than a GSXR front end swap)[/quote]agreed main problem with the brakes on a sv is the suspension also fitting larger calipers to the curvy model and running them in trackdays will bend the forks they are just not capable of handling larger calipers
Old 25-06-06, 12:27 AM   #69
I'm so sure that this isn't the case that I'm prepared to bet a whole scottish pound note on it... Total power's not the issue, you get no mure actual brute braking force from GSXR calipers than you do with SV bits (when they work). SV calipers will lock any tyre in the dry, the limit of braking force is traction not brakes. It's what you can do with it, and how it delivers it, that makes all the difference.
Old 25-06-06, 01:22 AM   #70
mart
i just agreed with your comment about the sv suspenshion and brake calipers with a note that running a bike set up for trackdays/racing which would include having dot/slick tires on in combination with larger 4 pot calipers which like it or not have a different force and action will distort the crapy forks that were fitted to the curvy models remember two pistons pushing equily on the disc not two pistons pulling the caliper to the disc agreed that the sv calipers have the same instant bite but would then fade were as the gsxr calipers would continue to gather power
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Gsxr Brake disks sv_rory Stuff Wanted 9 04-02-09 05:23 PM
torque wrench - conversions skint Bikes - Talk & Issues 0 12-03-07 09:27 PM
GSXR 600 Brake Pedal? cb9002 SV Talk, Tuning & Tweaking 3 27-01-07 12:04 PM
Front End conversions Blue_SV650S SV Talk, Tuning & Tweaking 27 18-06-06 05:07 PM
