Old 08-08-06, 03:06 PM   #61
Sudoxe
Originally Posted by kwak zzr
also running it with the side covers off so it aint overheating.
Take the CPU fan/heatsink off, check the termal paste and put the fan/heatsink back on make sure its on properly. P4's dont like having fans even the slightest bit loose.
Dan
Old 08-08-06, 03:09 PM   #62
SpankyHam
I thought he said his temps are all ok ?
Can't be bothered to read all posts again.
But try Speedfan - it shows you all Temps.
Old 08-08-06, 03:49 PM   #63
all temps are fine.
Old 08-08-06, 03:50 PM   #64
its not a p4 its a 2.8 amd.
Old 08-08-06, 03:52 PM   #65
have try'd all the cards, memory, psu, format,but it still does it but its intermitant it can be fine for hours then a right pain in the ass. its just shut down on me 4 times and not let me reboot kept getting bootup errors and jumbled bios?
Old 08-08-06, 03:53 PM   #66
Originally Posted by fizzwheel
Sounds main board or CPU problem.
I assuming that you have checked that the CPU cooling fan if your CPU is fitted with one is spinning. I used to find that these got gunked up with dust and fluff. They would then stop spining and fry the CPU which used to then make the PC crash and hang.
Shao's tip about unplugging everything and then plugging things in one by one till you have identified the culprit thats causing your trouble is a good one.
i'm now thinking mainboard or cpu i wish it would just break altogether it would be easy then.
Old 08-08-06, 03:53 PM   #67
fizzwheel
fizzwheel's Avatar
Personally from what you've said I think your motherboard is FUBAR.
Edit - One more thing. this will sound daft. But I've had troubles before with random rebooting caused by the motherboard shorting out on the mounts inside the case. Might be worth checking that out to.
Old 08-08-06, 03:54 PM   #68
Law
Athlon?
Old 08-08-06, 03:54 PM   #69
me 2 but its an expencive replacement if it turns out not to be.
Old 08-08-06, 03:58 PM   #70
yea Athlon 2.8xp
Computer help please Stu Idle Banter 7 09-11-08 07:28 PM
computer problem custard Idle Banter 19 06-09-08 12:50 PM
More computer help... JediGoat Idle Banter 1 17-09-06 01:24 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
