Old 25-03-08, 04:10 PM   #71
Default Re: 2000 sv650s redline
Right then first what sort of noise is it? Is it like a whine the VFR's make from their gear driven cams, or a wistle kind of sound?
My SV never made any whine sounds but the Falco does. Basically all this is down to is the gear driven parts of the engine of which there are a lot. The Sv has generally quiet gears in the engine but there is a chance that the gears are a little noisy and put out a whine. Id say its nothing to worry about. Get out and ride it
If its a wistle kind of sound then look into the Suction tubes and maybe even look if one of the rubber nipples have come off.
Does it seem to effect performance at all?
Yeah it's kinda like the VFR whine, but having a listen now it definately sounds like the front cam bearings.
Definately not the vacuum system as there's no popping and banging, and its coming from the wrong place. Sounds mechanical.
Old 25-03-08, 05:01 PM   #72
999nutta
only done about 300 miles since been back on the road. to be honest not got any worse or better. As above a definate mechanical noise. So you think front cam bearings. Is that an expensive/big job?
Old 25-03-08, 05:03 PM   #73
Cam bearings on dizzyblondes bike, yours seems different if it goes away when its on paddock stands.
As for being a hard job to do the cams, not really, about £50 for a new head and gasket and 2 hours to do it if that.
Old 26-03-08, 06:41 PM   #74
we had a good look today, cam chain fine, cam holders scored and cam bearings scored, that because my daft other half hittin the altermator plug with a impact driver, and me not noticing i had a leak. thus creating a low oil level, which I hoped hadn't got too low.
bearings whining. looks like a new head, but for now, some Zx1 has been put in, to see if it calms it temporarily
Old 26-03-08, 07:29 PM   #75
Yeah scored camshaft bearings. Not terminal yet, but they do need sorting so some Z1 oil additive has been dumped in to see if that helps!
Old 26-03-08, 08:28 PM   #76
jimmy
sounds like all of these problems are appearing on y2k bikes i've just bought mine just got to wait for a a restrictor to be fitted then it's all mine. has anything you've found so far seem to be extremely costly or affecting performance, i will let know if i have similar issues.
Old 26-03-08, 09:00 PM   #77
so far its not been costly, I think we caught it before the whole lot went bang, could still happen, but it was starved of oil IMO for not very long, it wasn't run very often or far enough. Fingers crossed for now, it'll stay on a level until i can get a new head, I'm just going to keep an eye on the bearing whining, as from experience at where i work, they'll soon get louder ad give you notice before going completely.
and at the moment there is no shortage of oil in there, and around where it should be coating
Old 26-03-08, 09:17 PM   #78
shifter
Is it safe to remove the camshaft holders for inspection without upsetting the timing? or do you need to line all the marks up.
Old 26-03-08, 09:26 PM   #79
couldn't tell you, you'd have to ask YC that.
Old 26-03-08, 09:33 PM   #80
shifter
YC, Is it safe to remove the camshaft holders for inspection without upsetting the timing? or do you need to line all the marks up
Swap for my sv650s 2000 SOLD ljharmitt For Sale - SV's and SV related items 17 28-06-09 01:48 AM
2000 sv650s in Blue pookie For Sale - SV's and SV related items 3 14-08-08 11:05 AM
Restriction kit for Sv650s 2000 Rosco-p-sv Stuff Wanted 6 13-01-08 05:35 PM
K&n Air Filter Sv650s (2000) lancasterlad Stuff Wanted 1 09-07-07 05:15 PM
