Old 19-08-09, 10:05 PM   #71
Von Teese
Default Re: anyone fancy a run up the A413 ?
Ahhhh I was wondering who that was...whooo hooo Messie!
I think you owe the boys a round in that then
Old 20-08-09, 08:06 AM   #72
plowsie
And if Messie won't we'll have to draw from a hat...Men need not apply...Deviants also!
Old 20-08-09, 09:27 AM   #73
Lucas
I'll join if I can get bike running
Old 20-08-09, 10:27 AM   #74
rictus01
rictus01's Avatar
still not found that electrical issue then ?
Old 20-08-09, 10:39 AM   #75
Lucas
battery goes flat if loom is left plugged in, it doesn't charge well when engine is running (only 10/11volts instated of 14 volts) and battery will go flat after 20 miles of riding with dancing clocks and xmas lights...(i did checked the condition of charging volts two weeks ago and was good)
Worked around the loom to find the cause and found that if the rectifier is unplug, the battery stops draining, which brings me to the conclusion that it just 'could' be a duffed rectifier. then again it could be the three yellow wires between the reg and the alternator thingy.
a second-hand replacement is on the way to try the theory this wknd...
Is it possible for a rectifier to 'deteriorate'
Old 20-08-09, 10:43 AM   #76
plowsie
In the best Churchill voice possible...'Ohhhh yessss'. I put a new one on one of mine after one went, it fudged that up, I replaced it with a CBR600F one and a new battery and there were no problemos.
Old 20-08-09, 10:58 AM   #77
Spiderman
Where the hell am I?
Spiderman's Avatar
Its also a good thing to rule out Lucas. When i had all my electric probs i was lucky enough that Empty's SV was off the road at the time and he knew his reg/rec was fine and kindly lent it to me for a week or so. Helped me discover that it wasn't the problem and the duff battery was.
Good luck mate, i hate electric problems with a vengance!
Old 21-08-09, 12:02 PM   #78
Messie
The Teacer
Messie's Avatar
What time would you be setting off from The Ace Mark?
Old 21-08-09, 01:51 PM   #79
rictus01
rictus01's Avatar
probabley 12 for a brew, leave a 12.30, something like that.
Cheers Mark.
Old 21-08-09, 02:20 PM   #80
Messie
The Teacer
Messie's Avatar
That's a good time for me so I shall probably see you there!
Does anyone Fancy... Mel Idle Banter 22 23-01-09 06:43 PM
Anyone fancy trying this? DMC Idle Banter 14 20-06-08 08:06 AM
A413 - Aylesbury to Buckingham thor Bikes - Talk & Issues 4 24-04-07 09:28 PM
Anyone fancy an MX-5? rob13 Idle Banter 3 22-02-06 09:52 AM
Anyone fancy... Jdubya The Essex Lounge 1 24-01-06 12:53 PM
