Old 26-08-12, 09:34 PM   #71
NTECUK
NTECUK's Avatar
Default Re: Help, I've screwed up the bottom shock bolt
Nm or ft lb its just a mesure of turning force.
That's the correct amount Hong
Old 27-08-12, 03:50 PM   #72
hongman
Cool. Let's see what Nitron have to say about it tomorrow!
Old 27-08-12, 04:42 PM   #73
Dabteacake
I always thought ft lb's and Nm are a lot different try it in google and it has 2 different values
http://www.thetoolhut.com/Torque-Con...sh-Metric.html
Old 27-08-12, 06:08 PM   #74
NTECUK
NTECUK's Avatar
If you did a bolt to 50 lb ft then yes it would be a different amount of force if you did it to 50Nm .
But what Chris said why use lb ft on a metric bolt. That's not the same as saying lb ft is the same as Nm or kg cm ..
Old 28-08-12, 12:35 PM   #75
hongman
Nitron are sending me out a new nut and bolt.
56mm length with 1 washer - definitely different from the last 2!
Techy is calling this afternoon/tomorrow too.
Old 30-08-12, 06:27 PM   #76
hongman
Update.
Fitted the new (shorter) bolt, which was a bit shorter and this time I torqued it up no issues, no sign of threading or anything. Solid, perfect.
However!
Even now with a single washer at the head of the bolt, as the Nitron tech told me to do, without a nut, the end of the bolt still touches the face of the dog bone *just*.
With the nut on and everything done up, the top face of the but is in 100% contact with the dog bone.
However this time it doesnt seem to impeding the shock function. Went up and down a few bumps, no loud metal on metal sound as before.
Seem to remember it sagging a bit more previously, and maybe I can contribute this to the contact adding slight friction, but then again it could be placebo.
What do you reckon guys?
Leave it, or pay more to have a garage look at it?
Most important thing is, is it safe?
Not taken her for a proper spin yet due to time contraints.
Old 30-08-12, 06:38 PM   #77
NTECUK
NTECUK's Avatar
Does the thread of the bolt protruded past the nylock part of the nut .
I think this is what your saying is touching the dog bone?
Old 30-08-12, 06:41 PM   #78
hongman
No, it doesnt - flush or just under.
Its the top face of the nut which is in contact. If it was a normal nut without the domed bit on top for the nylock part it would be ok, but its this bit that is touching.
Old 30-08-12, 06:43 PM   #79
hongman
Also, just to mention, I'm pretty sure I held the nut against the clevis with no bolt, and lined the dog bone up - still touches.
Old 30-08-12, 06:52 PM   #80
NTECUK
NTECUK's Avatar
Its the nylock that stops it undoing so you need that part.
From pics iv seen they are all very close .
When I put a nut n bolt on mine I used an "oddie" lock nut.
That ran close but just enough room.
Id query Nitron e mail a pic too.
ZX9 or 10 bottom suspension bolt DaveW_42 Stuff Wanted 0 21-05-10 11:29 AM
what shock bolt ? barwel1992 SV Talk, Tuning & Tweaking 2 06-10-09 11:04 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
