#71 | |
Btw i'd send anyone a few bob to help most out on here. The forums gave me more worth.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 19-02-13 at 08:09 PM. |
#72 |
Knob faced knobster
Ok so you see it as being a harsh reply, tell me what's harsh about it and any bits that you think are untrue/out of order
2011 Speed Triple 1050 |
#73 | |
#74 |
#75 |
I think your solution about the mods frog marching round was a bit ott. Im pretty sure craig is feeling bad enough about what happened without something like that being said. Your advice before you said that was fine.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 19-02-13 at 08:49 PM. |
#76 |
#78 | |
#79 |
does seem a bit strange to me that the people who run a forum could somehow be held responsible for stuff members sell on it
if you replied to an advert in your local paper and agreed to gift money on paypal and the seller then did a runner with the money, would you expect to get anywhere by complaining to the paper? its just a public internet forum, anyone can place an advert, anyone can read it, just like the local paper people buying stuff on here are lucky the mods are prepared to help at all IMO |
#80 |
+1 on that , and i carnt thank them enough for helping me , they dont have too ,
Sit back, watch and be amazed by idiots.. | speedplay | Idle Banter | 11 | 29-12-09 12:19 PM |
Lossless CD ripping - which program? | Nekkid | Idle Banter | 6 | 28-12-08 03:45 AM |
Ripping Yarns | tricky | Idle Banter | 1 | 18-05-07 08:36 PM |
Ripping music off a CD | Stu | Idle Banter | 11 | 09-09-06 01:56 PM |
Watch the guy in the back..... | TC3 | Idle Banter | 4 | 01-02-06 12:09 PM |
