Old 27-03-08, 09:18 AM   #81
skidmarx
Default Re: 2000 sv650s redline
This 'ere whining sounds like somebody overtightened the chain, knacked the output bearing behind front sprocket and sold it quick. I'm not sure how this works, but I would have thought that excess play on the output shaft in your 'box would have resulted in all sorts of whining as the gears may well be slightly out of alignment or something? But having said that, I've had EXACTLY the same issue with my cbr6 and it's got no worse/better in the last year, run perfick, I just make sure I've got me earplugs in.
Old 27-03-08, 10:57 AM   #82
Originally Posted by shifter View Post
YC, Is it safe to remove the camshaft holders for inspection without upsetting the timing? or do you need to line all the marks up
Far safer to do it at TDC with the camchain tensioner removed or at least locked back.
Doesn't have to be spot on, just wind it round to a point where no valves are open, but saying that you might as well check the valve clearances while you're in there.
Old 27-03-08, 04:41 PM   #83
999nutta
we had a good look today, cam chain fine, cam holders scored and cam bearings scored, that because my daft other half hittin the altermator plug with a impact driver, and me not noticing i had a leak. thus creating a low oil level, which I hoped hadn't got too low.
bearings whining. looks like a new head, but for now, some Zx1 has been put in, to see if it calms it temporarily
this zx1 stuff. showing my further ignorance how does this work and how much does it cost
Old 27-03-08, 04:44 PM   #84
Apparently its a friction reducer that builds a microscopic coating on metal parts.
It's not PTFE so it doesn't just clog the lot up.
Old 27-03-08, 04:49 PM   #85
999nutta
just had a look on net but can't seem to find anywhere that sells it. do you just add it to the oil and leave it in it.
Old 27-03-08, 04:53 PM   #86
yeah its an oil additive, 125ml in the oil.
I'd think carefully about using it. I'm not telling you to use it or not.
Old 27-03-08, 04:56 PM   #87
999nutta
i'm willing to give it a go. its that or look for some better ear plugs. annoying thing is whines worse with the plugs in as mutes out the exhaust and engine noise
Old 27-03-08, 06:09 PM   #88
shifter
Is it a good idea using friction reducing things with a wet clutch?
Old 27-03-08, 06:13 PM   #89
Not usually no, but the zx1 is alright with them
Old 27-03-08, 06:20 PM   #90
999nutta
so have you actually had the bike running now you've put the zx1 in. If so have you noticed any difference.
Swap for my sv650s 2000 SOLD ljharmitt For Sale - SV's and SV related items 17 28-06-09 01:48 AM
2000 sv650s in Blue pookie For Sale - SV's and SV related items 3 14-08-08 11:05 AM
Restriction kit for Sv650s 2000 Rosco-p-sv Stuff Wanted 6 13-01-08 05:35 PM
K&n Air Filter Sv650s (2000) lancasterlad Stuff Wanted 1 09-07-07 05:15 PM
