#81 | |
There will of course be a random error that will be different each time but I reckon it is small for GPS compared to a speedo which is more likely to be consistently showing a speed that is wrong due to calibration. |
#82 | ||
Thus decreased weight will increase your top speed. You could argue that drag increases with velocity and you would be right but it opens a can of worms in that drag isn't constant, it depends on air temperature, pressure, wind (and direction). But realistically it won't affect the forces as much as wieght of say, the bike or rider would on an SV anyway. Surely this is obvious? A bike and rider is maybe one fifth the size of a car, and much much quicker, you're not telling me bikes are so much faster than cars at speeds +80mph because of their drag coefficients, it's a weight game! |
#83 | |
First rider weighs 65kg, second rider weighs 140kg. Which test would see the bike achieve a higher speed, assuming that neither test runs out of road, ever? Last edited by Baph; 09-07-08 at 10:59 AM. |
#84 |
All subjective to the particular situation anyway.
Rolling resistance can be reduced at higher speeds with more rigid (read inflated to higher pressure) tyres. So it's not really that much of a factor... |
#85 |
When I say the top speed would be the speed of light I mean the limit is the speed of light, yes you'll never actually reach it.
#86 | |
#87 | |
However, weight is a factor, just a negligable one compared to drag. For anyone that doubts this, a simple test is to ride an SVS as fast as possible, then take the screen off & repeat (whilst rider remains in the same position for both tests). The second test there will have massively increased drag compared to the second, it will also be marginally lighter, but a lot slower. |
#88 | |||
However, the angular "tip" factor is only fractional at 46, rather than say 70! Personally I would guesstimate the difference is too great and the larger rider would still be slower, but without doing the maths it's only a guess. Quote:
![]() It was just an example to exagerate the effects of weight. I think you need a better understanding of forces IMO. Top speed and acceleration are both linked when talking about power to weight ratios and drag. They only vary differently with gearing. Quote:
The better test is that I've raced a naked many times, and the results are almost identical. These bikes have a similar PtoW yet massively different drag coefficients! PtoW all the way! |
#89 | |
When the engine is kicking out its maximum power the vehicle will continue to get faster until the friction equals the thrust provided by the engine regardless of the weight. I think some people think that it is "obvious" that weight plays a part in that we are so used to thinking about how quick a bike takes off compared to a car based on power/weight ratios, but top speed is a different matter. |
#90 | |
G-PACK for SV650 SV650S SV 650 SV650 S - EFI MODELS - Timing Retard Eliminator | ThEGr33k | SV Talk, Tuning & Tweaking | 0 | 25-11-07 12:22 AM |
70mph on my new sv650 naked im finding it hard to ride at that speed for long | jans1971 | Bikes - Talk & Issues | 28 | 31-08-07 09:14 PM |
will a 2002 sv650 s cylinder head fit my 99 sv650? | bugsy46 | Bikes - Talk & Issues | 2 | 07-04-07 04:26 PM |
Gods Speed ! ! !(top speed) | John 675 | Bikes - Talk & Issues | 15 | 13-03-07 09:43 PM |
2000 SV650 - sat in hot summer - now rough idle/slow speed | randallp | SV Talk, Tuning & Tweaking | 6 | 19-11-06 08:41 PM |
