Old 16-04-09, 08:18 AM   #81
TSM
The Sick Man
TSM's Avatar
Default Re: New battery required?
Originally Posted by Batteryman View Post
For a curvy you will need YT12A-BS for a pointy it is a YTX12-BS
Call the lovely Debbie on 0800 310 2100 to order.
Why not just get him to have a YTX14 (i know its a lil more money)?
I have one in my curvey and it fits fine, better for the cold starts.
Old 16-04-09, 09:09 AM   #82
Batteryman
The YT12A-BS and YTX14-BS share the sdame footprint, 150mm x 87mm but the YTX14-BS is tallerat 145mm, 40mm taller.
I wasn't sure there was 40mm spare space under the seat for the taller battery.
Performance wise the Yuasa YTX14 is 200A CCA rated and the Yuasa YT12A-BS is 175.
Capacity is larger at 12Ah v 10Ah.
If it will fit it would certainly give a bit more performance.
Old 16-04-09, 11:38 AM   #83
There should be enough room, but probably not if you have had to raise it to fit a proper rear shock.
Old 16-04-09, 01:47 PM   #84
TSM
The Sick Man
TSM's Avatar
Sorry i ment YTZ14, its not as high as a YTX14, mabey Varta dont do it, i know yausa do as thats what i have in my bike.
Old 16-04-09, 01:56 PM   #85
Batteryman
OK, yes the YTZ14 is 150 x 87mm as well, but 110mm tall making it pretty much the same same size as the original battery.
Yuasa make a YTZ14S and claim it is the only one with true YTZ technology. The Varta book claims the same 230A CCA rating however.
I only have the Yuasa one in stock.
Old 11-06-09, 08:58 AM   #86
slloyd
With all the talk of different battery types it's confused me this morning, even after the rocket fuel theyy call coffee.
Could I please have a summary on this....Require replacement battery for 2002 Curvey.
Current Battery: YT12A-BS
Other than a like for like replacement, what other battery can I use, without worrying about fitment?
Thanks.
Old 11-06-09, 09:06 AM   #87
Batteryman
Personally I would say replace it with either another YT12A-BS or a YTX9-BS, there is not a lot between them, the YT12A-BS costs a bit more and has a higher starting output, but either will start your bike fine.
Product Code: YT12A-BS
Brand:Yuasa
Voltage:12 v
Capacity:10 Ah
Dimensions:150mm x 87mm x 105mm
More info
Product Code: YTX9-BS
Brand:Yuasa
Voltage:12 v
Capacity:8 Ah
Weight:2.5 Kg
More info
Old 11-06-09, 09:13 AM   #88
slloyd
Thanks for the prompt reply batteryman, and I see you shop is out of stock until August
Ok, will have to shop around to see if I can get me one of these.
Old 11-06-09, 09:46 AM   #89
slloyd
Just spoke to a colleague of yours, as Debbie was on the "squark box" and he advised me that unfortunately August is the earliest date of delivery for the YT12A-BS so will see who else has one of these.
Thanks for your help.
Old 11-06-09, 09:56 AM   #90
Jinxy43
Slloyd I pick a YT12A-BS from Premier in West Wickham, just over 2 weeks ago, although it was slightly more expensive that Batteryman
Just thought you would like to know
K3 Battery required gerbrox Stuff Wanted 5 18-08-08 03:30 PM
New battery required SV Ste SV Talk, Tuning & Tweaking 3 19-12-05 03:28 PM
Prices for new battery required – urgently! Natasha SV Talk, Tuning & Tweaking 8 05-07-05 09:53 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
Battery required timboid SV Talk, Tuning & Tweaking 21 06-12-04 07:57 PM
