Old 09-04-09, 10:20 AM   #81
Luckypants
Luckypants's Avatar
Default Re: suspension question - what and why
Originally Posted by 21QUEST View Post
Anyhoos back to the point(re Alpinstars) currently been discussed, could well be the front is shooting up too fast...no?
Was my first though to, since that was the problem with the VFR forks. Too little rebound damping made the bike run wide mid-corner as they recovered from braking and powering out of the bend tended to tighten the line again.
New oil in standard SV forks might help here?
I am in total agreement with getting sag set correctly on all bikes....
Old 09-04-09, 10:27 AM   #82
Oil thickness affects rebound, there isn't much you can do to give the stock ones decent amounts of compression damping without turning them solid over bumps.
What springs have you ASH?
Old 09-04-09, 10:45 AM   #83
Domas
I've read somewhere here in site that fork oil can vary in viscosity even if they all state for example 10W. Is this true? Or maybe the difference isn't so big to really matter?
Anyway weighting 65kg, with stock springs and emulators, i'm thinking to put 10W. As I understand it would affect only rebound. So is 10W good enough for rough road riding?
Old 09-04-09, 10:54 AM   #84
Yes it's true.
No, with emulators you have some effect on compression damping too, so the oil is pretty important. Ask the people who make your emulators what oil.
Old 09-04-09, 12:18 PM   #85
flymo
flymo's Avatar
I went with 20W (was tricky to get hold of as I remember) oil on my race bike as recommended on the RaceTech suspension calculator. It feels totally rock hard at standstill compared to a stock SV but perfect when under hard load on a race track.
Old 09-04-09, 12:43 PM   #86
flymo
flymo's Avatar
anybody got access to one of these http://www.racetech.com/page.aspx?id=37&menuid=96
This would give the information we really need to setup properly.
Old 09-04-09, 01:30 PM   #87
Very very cool technology. I want one!
Old 09-04-09, 01:45 PM   #88
ThEGr33k
Nice. I want!!! I want!!!
Old 09-04-09, 02:42 PM   #89
flymo
flymo's Avatar
Please visit http://www.justgiving.com/flymos_racetech_bits
to raise money for my new RaceTech tools
Old 09-04-09, 09:38 PM   #90
lukemillar
I used 20W too.
Domas: I think Racetech recommend 20W, but check with them first. If you search through the archives for emulators by a user called BlueSV650S (i think) then he did a lot of playing around with emulators and weights of oil as he couldn't get them to work how everyone else was raving. I think in the end he used 20wt or a mix of 15wt and 20wt, but if you search, you'll find the whole story.
Racetech suspension question Jackie_Black SV Talk, Tuning & Tweaking 71 12-09-08 04:15 PM
Really quick suspension question stewie SV Talk, Tuning & Tweaking 10 28-03-08 09:55 PM
Car suspension question Warthog Idle Banter 8 08-12-07 04:03 AM
Easy suspension question stewie SV Talk, Tuning & Tweaking 47 13-10-07 05:54 PM
Suspension question pilot SV Talk, Tuning & Tweaking 7 14-09-07 06:23 PM
