Old 01-12-09, 09:49 PM   #81
ophic
ophic's Avatar
Default Re: Making my own heated grips controller
where did you get the rotary controller, Rictus? From another set of heated grips?
Silver SV650SK3, Fuel exhaust
Old 01-12-09, 10:12 PM   #82
embee
embee's Avatar
....and in case you're worried about running your battery down, simply wire one of these chappies into the supply and set the switching voltage at whatever you feel comfortable with.
Old 01-12-09, 10:45 PM   #83
ophic
ophic's Avatar
or just wire the grips to an ignition switched feed?
Old 01-12-09, 10:57 PM   #84
rictus01
rictus01's Avatar
the first was actually from a battery isolation switch box, but was a bit bulky, I've since changed it to the controller off a set of Daytons grips, which is much the same but smaller.
wire the relay to and ignition circuit, not the grips themselves as the draw could melt wires.
Cheers Mark.
Old 01-12-09, 10:59 PM   #85
tigersaw
tigersaw's Avatar
Odd design that. Cutoff in the negative line, which will do diddly for things connected to chassis, and using a MOS instead of a relay, which has its own voltage drop and gets hot.
Old 01-12-09, 11:29 PM   #86
xXBADGERXx
My mate has the rotary pot version of the hot Grips and has had them for Donkey`s Years , swears by the Pot and won`t touch the new ones . Not had a single issue with it . I , on the other hand , have had 2 controllers of the "Press and Hold for 3 Seconds" variety .
Old 01-12-09, 11:39 PM   #87
Find a suitable three way switch and connect such that there are two heated positions: Connected in parallel for hot, in series for warm.
And use a relay fired by the ignition switch for the supply, obviously.
Old 01-12-09, 11:51 PM   #88
ophic
ophic's Avatar
Now that's clever!
Old 01-12-09, 11:52 PM   #89
Spiderman
Where the hell am I?
Spiderman's Avatar
yeh its brilliant piece of work...just wish i knew what, where and how now, lol.
Old 02-12-09, 09:42 AM   #90
Dave20046
Dave20046's Avatar
my analog one blew up
R&G Heated grips gerbrox Ancillaries 9 27-07-09 03:00 PM
Heated grips Daywalker Bikes - Talk & Issues 3 17-02-09 01:08 PM
Heated Grips? smidge26 Riding Gear 41 09-11-08 01:06 PM
New oxford heated grips controller Alpinestarhero SV Talk, Tuning & Tweaking 21 30-09-08 03:00 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
