View Poll Results: How do you reduce your speed from a top gear? | |||
Brake hard and kick the gears down in one go to match the new speed |
15 | 25.86% |
Brake then down shift using the gears to slow the bike |
40 | 68.97% |
Slowing down?? wtf's that. Blat it all the way (p.s. this is not an option - don't click here) |
3 | 5.17% |
Voters: 58. You may not vote on this poll |
#81 | |
Silver SV650SK3, Fuel exhaust |
#82 |
If a child runs into the road I'll brake otherwise the engine and gears take care of it, I own an SV for ****s sake not a 4 pot
#83 |
can't say i've ever bothered too check how i'm slowing down just do it automatic.
#84 |
#85 |
#86 | |
Braking is not about locking the wheels, if fact it's more about not locking them I suppose. I'ts actually very easy to lock the front wheel with very little power, just grab a hadfull (or even 2 fingers full) when there is not much weight on it! I noticed one response extolled the virtues of 2 finger braking becasue it lets you keep 2 fingers on the lever all the time so you can get on the brakes early in town, but is that a good thing? You are far better using the (usually unused) rear brake (and on a V twin the throttle) to initiate braking and get onto the front once the weight has transferred even in an E stop situation. Unless the brakes have improved out of all proportion since the curvy I think you're doing well to lock the front when it's been firmly planted into grippy tarmac (assuming a decent tyre) with only 2 fingers. At the end of the day if you have tried bot methods and have worked out that for your style 2 fingers is best I'm not trying to convince you otherwise but I am concious that some visitors here are in thier early days of riding and it may be helpful to understand that there are alternatives which may suit them. Also, although this site is dedicated to the SV most people will move onto (and possibly already ride) other bike types which may work better with other techniques due to aspects such as less engine braking. In my case some reasons are physical and some historical. I find braking more controlled when the lever is closer to the bars (fingers closed rather than open) so even though my brakes are in good nick the lever can come close to the bars, i also find control easier when using less power which is possible with 4 fingers working at 50% rather than 2 at 100%. My early bikes were older technology and older physically (I'm not even going to put a figure on it!) so the brakes never had enough power even if you used both hands, they were also 2 strokes so I guess I didn't learn much about engine braking in my formative years. |
#87 |
I use the rear brake alot, mainly at speeds below 15 mph. Keeps my throttle hand free to operate just the throttle and do some of that niiiiccceee slow control stuff
You shouldnt be able to lock the brakes if you brake correctly. As YC said earlier on, if you grab a handfull, the front will lock, its not hard (I almost managed it the other day ![]() |
#88 | |
You should be able to avoid locking the brakes if you brake correctly. You should be able to lock the brakes, if you want to (except for ABS bikes).
#89 |
#90 | |
Certainly if you can't apply enough brake pressure with 2 fingers you shouldn't just use 2. Your first post said you don't understand why some people use 2 fingers on the brake, but if you can control the lever properly with 2 fingers it doesn't make much sense to use 4 imo. |
Moving on to IL4 - Change in Riding style? | rich_r | Bikes - Talk & Issues | 25 | 19-06-07 02:18 PM |
Thank you (Riding style) | scorpion | Bikes - Talk & Issues | 1 | 17-04-07 08:59 AM |
What a difference Riding Style makes to MPG!!! | SpankyHam | Bikes - Talk & Issues | 43 | 06-07-06 04:23 PM |
Rev it! Riding style questions. | Bud | Bikes - Talk & Issues | 11 | 24-03-05 10:22 PM |
Rev it! Riding style questions. | cotwbs | SV Talk, Tuning & Tweaking | 10 | 04-01-70 05:29 AM |
