Old 07-04-10, 06:29 PM   #81
Default Re: What fork springs? brand and type.
http://www.peterverdonedesigns.com/lowspeed.htm
Old 07-04-10, 06:31 PM   #82
barwel1992
well the 15w motul expert has a 77 cst@40c
Old 07-04-10, 06:41 PM   #83
A different site reckons it is 57cSt.
Old 07-04-10, 06:45 PM   #84
-Ralph-
OK, did you get that from another source as I can only see Motul Comfort on the table YC just posted.
What does that cst figure mean? Is that my problem?
Old 07-04-10, 06:47 PM   #85
I think motul make a number of oils with similar ratings. Source I have is not confirmed reliable either.
Best bet is to email motul.
Barwel be careful with that table, just because it is same maker and same SAE rating (5w, 10w, whatever) does not mean it's on about the same oil.
Look at silkolene... they make "fork oil 5W" and "Pro RSF 5" which are both nominally 5w but quite different oils.
Old 07-04-10, 07:02 PM   #86
-Ralph-
OK, found a PDF from Motul
http://www.motul.com.au/product_line...LEND_CHART.pdf
15w = 57.1
50% 15w + 50% 10w = 45.1
10w = 35.9
It also says Factory line Medium 10w is 35.9 as well.
The peterverdondesigns page says damper rod forks should use 34
So I think I'm going to buy a bottle of the 10w and try that, then if it's not thick enough I'll buy another bottle of 15w and do a 50/50 mix.
Old 07-04-10, 09:10 PM   #87
barwel1992
yeh i know because the fork oil i have "factory line" has a lower cst than the other motul comfort stuf
and searching for motul comfort brings back nothing so i presumed it was motul expert
Old 07-04-10, 09:52 PM   #88
I don't see why you press point when motul website proves your assumption was wrong.
Old 07-04-10, 10:08 PM   #89
barwel1992
i was just answering what you wrote
no need to blow a head gasket now is there
Old 07-04-10, 10:12 PM   #90
"I presume" is in the present tense, which implies you still presume despite being proven wrong. Seems a little odd.
Who is blowing gaskets, I do this for fun
Anyway it would be prudent to state if something isn't clear. People aren't too friendly if you advise them based on assumptions and guesswork and they then go and spend their money on the wrong thing.
Pointy Progressive springs (brand new) ivantate For Sale - SV's and SV related items 10 25-07-08 03:31 PM
Fork Springs Khewett SV Talk, Tuning & Tweaking 5 24-01-06 11:23 PM
fork springs jim@55 Stuff Wanted 0 18-01-06 06:58 PM
Fork Springs carelesschucca SV Talk, Tuning & Tweaking 8 29-01-05 01:31 AM
Fork Springs? bobit69 SV Talk, Tuning & Tweaking 3 21-01-05 10:34 AM
