Old 05-02-08, 01:51 PM   #1
husky03
Default compressor
I'm looking to get myself a compressor so i can start doing my own paint work-just looking for a recommendation of whats required from the compressor eg-minimum capacity etc
cheers
husky
Old 05-02-08, 02:09 PM   #2
Caddy2000
Default Re: compressor
A big one with a big motor with a large flow rate.
Think I remember something about certain compressors leaving a bit of oil in the air (which can't be good)
Old 05-02-08, 02:21 PM   #3
timwilky
timwilky's Avatar
I have two feeds from mine, one through evaporator filter/lubricator and a second through an evaporator filter. My lines have different fittings so those to air tools requiring oiling will only fit the line to the lubricator etc.
That way I am doing my best to ensure no oil can get near my paint.
I also have a tee off for my air fed mask. Please if you are going to DIY paint don't use 2 packs without a good mask. No sense killing yourself.
I also have a couple of guns as for some reason red despite a good cleaning will always bleed out whenever I paint white etc.
BTW, I am no expert, I do the occasional bodge. But have enough friends who are proper panel beaters, painters etc to get a professional job done at the right price, ie cheap/free/materials only etc.
Not Grumpy, opinionated.
Old 05-02-08, 02:44 PM   #4
husky03
so an oil free compressor would be the better to get?
Old 05-02-08, 08:15 PM   #5
Davie
Try here http://www.machinemart.co.uk/
they have a shop on the great western road not far from HG
Old 05-02-08, 08:21 PM   #6
Keith1983
If you are only looking to paint with it then I presume an oil free one will be fine however if you are looking to use it for powering grinders, nut runners, or any kind of air powered tool then that will most likely require lubrication.
Who needs a compressor .. Blue_SV650S Idle Banter 15 26-04-08 08:35 AM
aldi air compressor. ejohnh SV Talk, Tuning & Tweaking 19 28-03-08 08:23 AM
Compressor for sale northwind SV Ecosse 1 25-09-07 08:22 AM
How big a compressor do I want? northwind SV Talk, Tuning & Tweaking 20 05-07-05 12:10 PM
12V compressor for tyres embee Ancillaries 1 14-02-05 10:24 PM
Powered by vBulletin® - Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
