10-07-09, 10:21 AM | #1 |
Stroking a 2-stroke.
I know where there is 2-stroke 250, that I might be laying my hands on. Now it probably hasn't been running for about 5 years now. I think there is still some oil in it, and I know the last time it had a battery it did run. As I rode it.
Now is there anything I need to know about stroking a 2-stroke back to life other then the usual thing of first replacing all the oil/liquids in the bike. Just so you know its a Kawasaki KR1-S C2. |
10-07-09, 10:35 AM | #2 |
Re: Stroking a 2-stroke.
check the tyres & brakes, swap the engine oil (if you care about the motor), renew the petrol (don't forget to mix in some two stroke oil!) get some easy start to hand( or if you're feeling crude wd40 up the air intake). Try charging the battery and get ready for some exercise (kickstart). Might be an idea to swap the plugs / give it a full service - are you indending to run it?
10-07-09, 11:11 AM | #3 |
If it were me id strip the top end and replace the piston rings. It will take you half a day and cost about £30. Whist your there you could give it a good inspection!
Then give it a dam good warm up before you ride. |
10-07-09, 11:43 AM | #4 | |
Not sure about modernish 2 strokes, but the main oil seals used to be a problem if 2 stroke engine was left for a while. They dry out and then you get no/little/poor compression. No way of telling unless you try it! But the info could save you heaps of time if it isn't running very well.... ps, I'd run some oil down the bores and hand crank it for a bit in case it's seized up with gunk.. |
10-07-09, 12:00 PM | #5 |
I'm another subscriber to whop the barrels off & change the rings.
KR1? Last edited by Sosha; 10-07-09 at 12:02 PM. |
10-07-09, 12:06 PM | #6 | |||
I shouldn't need to mix the 2 stroke oil as it mixes itself as far as I recall, or are you recomending I add a little more. The battery is duff, but I have some overs about that I can use to get it running. Yes its a kickstart, the last time I had it running it was 15 kicks before it fired. The plan is to put it on the road. Quote:
10-07-09, 12:12 PM | #7 |
Here you go... I found a old photo -
10-07-09, 12:13 PM | #8 | |
EDIT: Kewwwwl Last edited by Sosha; 10-07-09 at 12:15 PM. |
10-07-09, 12:17 PM | #9 |
Trinity
Forgive the semi derail. I didn't know 2 strokes used engine oil, other than the oil you pemix or the bike mixes with the petrol
Beautiful photo Get it running again |
10-07-09, 12:21 PM | #10 |
according to two smoke blue stroke at the end of the couch
check the suspension bearings, cause they can be deathtraps if not working properly.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
2 Stroke Help | DarrenSV650S | Bikes - Talk & Issues | 2 | 10-05-09 03:16 PM |
Stroking? Pleasurable? No that can't be right! | missyburd | Idle Banter | 4 | 12-04-09 11:37 PM |
I think I want a 500 2-stroke! | ThEGr33k | Bikes - Talk & Issues | 59 | 27-12-08 11:00 AM |
Ever used 2-stroke oil in your 4-stroke fuel?? | Blue_SV650S | Bikes - Talk & Issues | 3 | 19-08-06 07:22 PM |
2 Stroke HELP!! | Last Action Pimp | Bikes - Talk & Issues | 8 | 26-11-05 01:41 PM |
