Just a thought really... Is it worth covering the front downpipe with exhaust wrap? Mainly to prevent corrossion/road crud and prolong its life.
I know it doesn't look the best but it would save alot of cleaning and hopefully keep the downpipe nice for when you come to sell. |
It would be fine if you only rode in the dry but after a couple of hundred wet miles riding it would look very shabby and the water stays against the pipes really making the problem worse.
Ah yeah, good point that lol! Obviously wouldn't want to be replacing it too often due to cost. Unless the heat from the exhaust would dry off any water on/around the wrap, maybe leave it running 5-10 minutes after a wet journey?
You could get someone to make up a stainless steel guard similar to the guard on the exhaust under the footpeg, which fastened under manifold bolts and extended to where the pipe curves towards the underside of the engine? Just a thought.
I run it on my race bike and usually change it after a wet weekend.
Fender extenders get good press. Doesnt solve the problem but certainly helps. |
Yeah mine has a fender extender and I shall be fitting a pyramid bellypan sometime this week, which will hopefully help a bit too.
To be honest I use it to seperate the downpipe from the bodywork as it is quite a tight fit. Just stops the heat scortching the bellypan.
#9 |
Gotcha, thanks.
C |
#10 |
Polish the front downpipe and give it some TLC...much better than manky wraps.
However, I do need some exhaust wrap for the rear downpipe of my VRaptor, as they have a nice penchant for boiling their shocks, as the downpipe get so hot, and its placed in a very close proximity to the shock. Apart from evilbay where do I find it, as they certainly don't cater for it in Halfrauds.
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
Exhaust heat wrap | flymo | Stuff Wanted | 0 | 22-02-09 09:48 PM |
Exhaust Wrap | lawson17 | SV Talk, Tuning & Tweaking | 12 | 18-01-09 09:44 AM |
Exhaust,front downpipe clamp. | ejohnh | SV Talk, Tuning & Tweaking | 4 | 18-08-08 11:54 PM |
Exhaust heat wrap or cloth? | pencil shavings | SV Talk, Tuning & Tweaking | 6 | 13-09-07 05:49 PM |
exhaust downpipe | hutchy | SV Talk, Tuning & Tweaking | 10 | 19-01-06 03:04 PM |
