Old 16-08-22, 06:12 AM   #1
Geodude
Geodude's Avatar
Default Footrest/brake pedal
Having same problem (on friends bike. K6 sv650) as Girth did in the thread below with brake pedal binding after strip, clean and re assembly?
http://forums.sv650.org/showthread.php?t=157826
Quote from Girth in above link: Hey,
Cleaned up my rear caliper, thought I'd clean up the brake pedal pivot. Stripped the foot peg out, cleaned up and gone to put it all back together as I thought it was. The bloody brake pedal has gone tight, double checked and check again on how it was assembled and I've drawn a blank.
There is a washer that sits on top of the foot peg (or at least i think) that is present but as soon as I tighten the bolt up into the footpeg the brake pedal goes tight. Without the washer the brake pedal floats about on the foot peg.....
Help
Anyone got any ideas or had the same problem?
Old 16-08-22, 09:28 AM   #2
Default Re: Footrest/brake pedal
if you greased the pivot it could be the grease causing stiction. IIR i had the same problem.
remedy is to remove the MC link rod from the cleat and give the pedal a good old push and wiggle till it frees up.
if you haven't greased the pivot then do it.
also you could have tightened the bolt too much.
Old 16-08-22, 10:52 AM   #3
Geodude
Geodude's Avatar
Hey my lover thanks for reply. Will give that a go cheers. I can't get my head round the fact it all worked before cleaning and was re assembled properly with the washer etc and wont budge but if you take out the thin washer it slops about when tightened up, surely the washer can't change the space that much. Hmm
Old 16-08-22, 10:56 AM   #4
as said you might have tightened the bolt too much. if all else fails shave a bit off the pedal to bolt hole surface.
have you checked that the pedal moves freely before attaching the MC rod?
Old 16-08-22, 11:08 AM   #5
Geodude
Geodude's Avatar
As far as im aware it was disconnected from m/c rod. Might give the shave thing a go when i get chance. Still strange how it seems to have changed size/tolerance just by cleaning it If you take washer off and then as an experiment push it into the gap between pedal and mounting plate it takes up the slop and works, but if you put it back on properly it wont move. Why don't you live next door Bibs xGx
Old 16-08-22, 03:01 PM   #6
Geodude
Geodude's Avatar
Firstly thanks Bibs for guidance as always. Ok for anyone else that has the same problem here's something that might help you.
After much head scratching and bibs help and comment on shaving, it turns out that the foot peg has been a little loose for a while (and if i can explain this well enough) and has worn down the area where it mounts just enough so that when its been cleaned and reinstalled it acts like a vice on the brake pedal, so the washer is too thick now, so slightly thinner washer equals less grip on brake pedal and lets it move again.
Now i hope my explanation helps with anyone else who has same problem
Pointy rear footrest and brake lever/pedal doofus4000 For Sale - SV's and SV related items 6 12-10-13 12:39 PM
RHS footrest hanger & brake pedal kickingkh Stuff Wanted 0 20-06-12 08:54 PM
Riders footrest/brake pedal Girth SV Talk, Tuning & Tweaking 7 29-09-10 07:17 PM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
SV650 R/H footrest peg brake pedal full assembly mgilbe For Sale - SV's and SV related items 1 23-01-08 10:58 AM
