22-08-05, 10:35 PM | #1 |
TRE on SV650s k4
hello, does this work on one this bike, its been fitted with a Remus revoltuion (baffle removed) the bike feels gutless and i want more power
many thanks |
22-08-05, 10:37 PM | #2 |
Yes, it does work, but I'm not convinced you're going to get enough to satisfy you if you think the SV is gutless.
22-08-05, 10:48 PM | #3 |
it gives it a bit more grunt though?? any other good ideas i`m changing the front sprocket down 1 tooth and checked chain tension and tyre pressures
22-08-05, 10:51 PM | #4 |
I think down one tooth on the front and up a few on the back will work wonders, though check that with somebody who's done it.
I know the SV isn't a power monster in any sense of the word, but I wouldn't ever call it gutless. |
24-08-05, 05:34 PM | #5 |
i dont think the tre works on the 650 only the 1000 you could try a g pack or save the money and get new race spec cams
24-08-05, 05:47 PM | #6 | |
24-08-05, 08:11 PM | #7 |
are you sure you can buy a tre for the sv 650s k3 on
24-08-05, 08:29 PM | #9 |
nice one for all the trouble though you could just fit a timing advance key to the motor
24-08-05, 08:33 PM | #10 | |
A timing advance key will permanently advance the timing, doing the TRE mod will remove a retardation to the timing in (I believe) 2nd and 3rd which was put there to reduce noise. Unfortunately, I think the TRE mod also loses the ECUs ability to know what gear you're in and use the appropriate map for that gear. Whether this is an issue on an SV, I don't know. I haven't done the mod because I want more power but well outside what I know the SV can ever put out. |
Sv650s oil | SUPERSTARDJ01 | SV Talk, Tuning & Tweaking | 4 | 26-04-09 03:58 PM |
04 sv650s | SVRIDER07 | For Sale - SV's and SV related items | 1 | 07-08-07 10:21 PM |
SV650S, K3, 04 Reg | machra | For Sale - SV's and SV related items | 0 | 03-07-06 05:48 PM |
various for SV650S K5 | richbeales | Stuff Wanted | 5 | 17-04-06 12:23 PM |
SV650S K3 | Caddy2000 | Bikes - Talk & Issues | 9 | 04-09-05 08:29 PM |
