Theres a set on ebay quite close to me
http://cgi.ebay.co.uk/YZF-R1-Forks-9...QQcmdZViewItem Whats involved in a conversion?
I think it was r4ce_e3nd who fitted some.
'52 Curvy S | So good.....it made me want to trump! If at first you don't succeed - use more gaffa tape. |
You need a modified top yoke. The R1 forks are fatter.
TBH save yourself the problems Gixxer k4-5 forks fit streight in! All you have to do is make your own speedo drive... (not that hard to be honest!)
gregmli.blogspot.com/search/label/motorcycle There is everything you should need on that site, its brilliant! ![]() (search for 'GSX-R Front-End Swap Parts Compatibility' on that page). http://forums.sv650.org/showthread.php?t=96370&page=2 Last edited by ThEGr33k; 15-11-07 at 07:02 PM. |
True!
What I've used is: -R1 forks -R1 wheel + discs -R1 calipers (verry good stuff) -R1 spindel -SRAD 750 top and bottom yokes -SV stem -TL clipons -a spacer for the top yoke -spacers of 2mm thick for the calipers and the wheel (because the center-center width of the yokes is 4mm to wide) Why I didn't use the R1 yokes? To much trouble fitting the stem into the yokes. The advantage of the SRAD one is also that you can use the steeringlok with a little modification to the frame (enlargen the hole a little). But I stil didn't come to that... I think they look realy good. They aren't the best ones, I've heard gsxr ones are a wee bit better, but they do the job! |
USD GSXR1000 k1 forks | standed forks - curvy | Nicky S | SV Talk, Tuning & Tweaking | 113 | 07-09-09 01:12 PM |
forks | jon8oy | SV Talk, Tuning & Tweaking | 26 | 04-12-07 08:34 PM |
Forks | markmoto | SV Talk, Tuning & Tweaking | 7 | 13-07-07 12:22 PM |
New forks ?? | Stig | Photos | 12 | 02-01-06 08:39 PM |
Forks | Viney | SV Talk, Tuning & Tweaking | 11 | 14-03-05 08:52 AM |
