Old 01-09-25, 10:24 AM   #11
garynortheast
garynortheast's Avatar
Default Re: Tyres
A job to be done sometime during the next week or two.
Blue Curvy S with over 112,000 miles and still going strong.
Last edited by garynortheast; 30-09-25 at 07:22 PM. Reason: New image hosting service
Old 01-09-25, 12:13 PM   #12
Luckypants
Luckypants's Avatar
Default Re: Tyres
Will the taller tyre make your speedo under read? It will rotate slightly more slowly than a 120/60 but I'm sure its not significant enough to be an issue.
Old 01-09-25, 12:45 PM   #13
garynortheast
Default Re: Tyres
It's apparently 4% Mike, but the speedo was always optimistic anyway. I'll check it against a satnav/gps reading when I get them on. If needs be I could stick a speedo healer in there I think.
Old 01-09-25, 02:38 PM   #14
glang
Default Re: Tyres
yes to avoid legal problems most vehicles speedos show slightly higher than the actual speed so a bigger diameter tyre can correct this...
Old 01-09-25, 02:48 PM   #15
Luckypants
Luckypants's Avatar
Default Re: Tyres
Quite likely to be within the bounds of acceptable then.
Old 01-09-25, 04:52 PM   #16
garynortheast
Default Re: Tyres
Hey, I might have an accurate speedo for the first time ever!
Old 06-09-25, 10:39 AM   #17
Default Re: Tyres
Must say Gary for a bike thats done 112k+ miles its in increadable condition. Your a credit to that bike.
Old 06-09-25, 04:00 PM   #18
garynortheast
Default Re: Tyres
Thanks Lance. I have to say I don't have to do much to it. I keep it relatively clean and give it a coat of ACF50 each time I wash it. Aside from that I just do the basics - change the oil every 5000 miles (fully synthetic) and keep it topped up, check tyre pressures, keep the Scottoiler topped up and tension the chain on the rare occasions it needs doing. Aside from that I just ride it. I don't ride that slowly, but I don't spend my time wringing it's neck either.
I've had it for more than 15 years now, still makes me smile.
Old 07-09-25, 07:10 PM   #19
NedSVS
Default Re: Tyres
I'm still running a 60s profile front and I'm not convinced that Suzuki even bothered recalibrating for the 60s profile tyres, versus the 70's. When I go out for a group ride my mileage covered, on the trip meter, is always higher than the others.
I have run 70s profile fronts in the past and the only thing I didn't like, was the horrible noise stones/gravel make when they stick to your tyre and scrape the inside of the mudguard. I strongly recommend 36psi as well, because the stock 33psi leads to a strange wear pattern in the middle.
Old 09-09-25, 01:58 PM   #20
garynortheast
Default Re: Tyres
Thanks for that Ned, I'll bear it in mind.
Replacement car tyres and tyres labels Kenzie Idle Banter 7 20-03-24 11:06 AM
Bike Tyres Leeds - free fitting on Michelin Tyres through Feb & March Paul the 6th Pennine Massive 14 03-03-12 04:59 PM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
Tyres oh tiring tyres 454697819 SV Talk, Tuning & Tweaking 15 13-10-04 08:40 PM
