Old 22-01-08, 08:49 AM   #1
flymo
flymo's Avatar
Default Wiring loom query
Hi all,
I've been stripping out an alarm system and attempting to trace and connect a number of black wires. Sorted myself out with the SV650 K3 wiring diagram and traced them back to the only item on the diagram that has no name or obvious role. Anybody got a clue what it is? I'm assuming some sort of connector or terminal block that was removed from my loom before I got it.
Piccy attached. The item is on the bottom right hand corner of the wiring diagram.
Mike
Old 22-01-08, 09:26 AM   #2
zadar
Default Re: Wiring loom query
actually there is no connector or terminal in harness.what you see in diagram is just bunch of ground wires tied together.
Old 22-01-08, 05:52 PM   #3
flymo
flymo's Avatar
Thanks, but I've done some more detailed testing and I dont think thats the case. There may not be a connector there but one things for sure, they dont connect together.
Two of them do, and the other three are insulated from each other. Bike running fine now.
Old 22-01-08, 08:00 PM   #4
zadar
you right,I thought it just represents ground wires but after looking at diagram I believe this is resistor that 03 does not have.newer ones do.ceramic looking thing attached to left side of subframe under passenger seat.
Old 23-01-08, 09:08 AM   #5
flymo
flymo's Avatar
Sorted, looked at a replacement loom and as thought it has an unused connector block, all the wires are isolated except two.
Wiring Loom Cost? Binky Bikes - Talk & Issues 11 19-08-08 09:31 PM
Wiring loom Binky Stuff Wanted 3 19-08-08 08:24 PM
Wiring loom bits. SoulKiss Stuff Wanted 0 21-05-07 01:49 PM
Wiring Loom GSXR Carlos SV Talk, Tuning & Tweaking 0 04-09-05 01:28 PM
Who was after a K3 wiring loom? Mike1234 SV Talk, Tuning & Tweaking 0 14-02-05 11:56 AM
