Old 04-06-10, 05:55 PM   #1
barwel1992
Default clutch drag - how much it to much
ok so i have the bike jacked up so the rear wheel can spin, and today put on a new sprocket, and decided to clean the worm drive.
so after putting the worm drive back on and decided to test the clutch, so i put the bike in first so the wheel wont spin then pull in the clutch and the wheel will turn but takes a lot off effort to turn the wheel (by hand) im sure that thats not right, so then i put the bike in second and it takes less force to turn with the clutch in.
so basilica i want to know if the wheel should free wheel when the clutch is pulled in when in gear (as it does when in neutral) or should there be resistance
PS the worm drive (clutch realise mechanism) works fine
thanks
Old 04-06-10, 06:02 PM   #2
Richie
fantabulas
Richie's Avatar
Default Re: clutch drag - how much it to much
sometimes their might be a bit of resistance if the engine oil temp is cold....but not a TOO much... (if bike is on both wheels and clutch pulled in and a first gear is selected the bike should not be pulling forward)
you might have maladjusted the clutch worm drive by accident on replacing it. just a thought.
My Flickr photos
Old 04-06-10, 06:02 PM   #3
simesb
Is the oil cold or hot? Cold oil can cause resistance which will disappear when warm. I couldn't bump start my SV on a cold day as the rear would just lock, but otherwise my clutch seemed fine.
Old 04-06-10, 06:06 PM   #4
barwel1992
cold, i cant start the bike at the moment
although might drop the air box back on so i can start it up
Clutch drag and oil choice doser SV Talk, Tuning & Tweaking 22 11-07-13 06:08 AM
Drag me to hell GeneticBubble Idle Banter 5 06-06-09 09:15 PM
Clutch drag, reasons/solutions? nicky-jano SV Talk, Tuning & Tweaking 8 09-03-09 08:49 PM
A total drag! n I don't know why lib-biker SV Talk, Tuning & Tweaking 2 08-06-07 11:15 AM
Clutch Drag - calling sid squid ;-) goof SV Talk, Tuning & Tweaking 20 15-06-06 04:17 PM
