Old 10-11-07, 12:29 AM   #1
plowsie
Default Air Filter?
Is it as easy as it looks?
Pull out, put in?
Old 10-11-07, 12:57 AM   #2
Razor
Default Re: Air Filter?
Yup, just don't drop anything into the airbox.
Old 10-11-07, 07:24 AM   #3
petevtwin650
Yep,just the 4 cross head screws. but make sure you use a good fitting driver as they can be tight. Also the seal will make it hard to lift out. Don't panic if you see lots of oil in the box. Pretty usual IME. Just swab it out.
Old 10-11-07, 09:55 AM   #4
even i can do it
K&N Air Filter markryker SV Talk, Tuning & Tweaking 11 29-03-09 09:08 PM
K&n Air Filter lancasterlad Ancillaries 12 23-11-07 04:24 AM
K&N Filter Phantomtek Stuff Wanted 1 25-04-07 05:48 PM
oil, filter and air filter change doe SV Talk, Tuning & Tweaking 10 17-04-06 01:29 PM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
