Old 13-11-07, 06:59 PM   #1
Alpinestarhero
Default Polishing plastic?
I need to polish the edge of a peice of polycarbonate plastic to a shine...optical polishing, if you will. How can I get it like this? I've smoothed the edge down with sandpaper, then with wet and dry...if I keep using finer and finer grades of wet and dry will it become shiny smooth? Or always dull? I'm a bit hesitant to use any polishing liquids, incase it interferes with the experiment I m planning to do with the material
Matt
Old 13-11-07, 07:07 PM   #2
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: Polishing plastic?
if i can remember back to DT at school, i used fine wet and dry, it should work
05 DRZ400E
RIP hovis
Old 13-11-07, 07:25 PM   #3
Kate Moss
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 13-11-07, 08:19 PM   #4
tigersaw
tigersaw's Avatar
I have special stuff I used when restoring pinball machines, but I found metal polish or T cut worked just as well
Old 14-11-07, 08:45 AM   #5
Alpinestarhero
I'll give that a go tigersaw, I should be able to find something to make sure the surface is mega clean (its gonna be used for scanning electron microscopy to view the layers of material...the anti-scratch coating etc, so it needs to be really polished and clean)
Mrs_24/7....sorry for the boring question, but you didnt have to read it
Matt
Old 14-11-07, 08:51 AM   #6
hovis
get mrs alpinsstarshero to do it............ after all its a womens job, Polishing
Old 14-11-07, 09:00 AM   #7
Alpinestarhero
Run hovis, RuN!!!! You'll get a slap for that
Good idea though...
Matt
Old 14-11-07, 10:07 AM   #8
FG1
It may well be a womans job, but............................if you want it doing properly................................
OK I am getting my coat.
Old 14-11-07, 10:37 AM   #9
Bluepete
Bluepete's Avatar
Brasso and a soft duster. Worked at school on perspex edges for me!
Old 14-11-07, 11:11 AM   #10
Alpinestarhero
Autosol is working!!! Figured it was similar to brasso, being metal polish (well, thats the only similarity)
Matt
What plastic are the plastic bits made out of? Mark_h SV Talk, Tuning & Tweaking 3 24-03-08 08:32 PM
Plastic / Fairing Repair (Plastic Welding) Solution MattP SV Talk, Tuning & Tweaking 2 29-06-06 04:14 PM
polishing. kwak zzr SV Talk, Tuning & Tweaking 2 25-06-06 07:09 PM
Polishing GSXR Carlos SV Talk, Tuning & Tweaking 0 12-06-05 02:19 PM
Polishing pencil shavings SV Talk, Tuning & Tweaking 8 10-01-05 11:59 PM
