Old 15-11-07, 07:51 PM   #1
Default what to do with the belt when removing the rear wheel on a buell
my mate needs a tyre on his buell but what happens with the belt tensioner?
is it just a case of remove it or what? anyone ever messed with a buell back wheel?
Old 15-11-07, 08:14 PM   #2
Default Re: what to do with the belt when removing the rear wheel on a buell
what buell is it. Im indoors requires the detail so he can give you the answer.
Old 15-11-07, 08:35 PM   #3
rictus01
rictus01's Avatar
the standard tensioner is fixed and held on by a couple of bolts and needs to be removed, however most people change this for the trojon horse spring one which you can just push back, so it depends on if this has been changed.
this was on a XB9S. not having worked on a 12 I can't say if this is the same on them.
Cheers Mark.
Old 15-11-07, 08:42 PM   #4
matt says what Rictus said, if in doubt go here
http://www.ukbeg.com/
its the buell enthusiasts site. Im indoors and his mates lurk on there. Should be some advice somewhere for ya too.
Old 15-11-07, 09:00 PM   #5
yea its the standard xb12r set up with the fixed tension wheel, will pass the info onto my mate with the buell, he will thank you for your input.
Removing the rear wheel gilby104 SV Talk, Tuning & Tweaking 20 26-09-08 08:27 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Removing rear fender Jamie Slick SV Talk, Tuning & Tweaking 1 26-04-08 07:20 AM
Removing the mudguard - front wheel off? Tiger 55 SV Talk, Tuning & Tweaking 14 29-08-07 10:54 AM
Removing rear fairing elqueson SV Talk, Tuning & Tweaking 15 14-11-06 08:58 PM
