I know the noobie asking another dumb question but you guys all seem great and dont mind
Sorry computer must have froze with 2 threads now
I rarely get this VERY rarely! Its come back up through the Carbs/FI... More than that i cannot tell you but i will be interested to know what it might be!
Morning all.
It sounds like a minor spit back through the throttle bodies, most petrol engines do this sometimes. It's more common on engines with fewer cylinders like a V twin, as the cylinder that's firing effectively has to do more work, as there is comparatively more resistance from the other cylinder. As compared to a 4 cylinder engine where the firing cylinder is assisted by other cylinders that are on the down stroke, (it's all torque you know) ![]() As, like you said it's the running in period I wouldn't worry too much about it. Most engines do not perform their best until they're fully run in. It would be worth mentioning it at the 600 mile service, just in case there is a slight leak on one of the inlet manifolds, or on one of the vacuum hoses. Cheers. |
So what does that mean for mine at 24K miles?
Looking at your picture I would say that the non standard can & doubtless other bolt on bits would contribute to it.
Like I said most engines do this at some stage, so providing the mixtures are ok it's nothing to worry about. Cheers. |
I wasnt so much worrying, just making sure i shouldn't
ok, thanks for the info
Car engine problem question | rob13 | Idle Banter | 10 | 23-02-08 08:23 PM |
Engine popping question | KillaSV | SV Talk, Tuning & Tweaking | 0 | 17-11-07 03:38 AM |
Engine temp question... | marky | SV Talk, Tuning & Tweaking | 7 | 15-08-06 08:59 AM |
Engine removal question | tradedog | SV Talk, Tuning & Tweaking | 7 | 20-05-06 11:39 PM |
engine oil question | w1ll15 | SV Talk, Tuning & Tweaking | 7 | 08-05-06 10:58 AM |
