Old 23-11-07, 08:35 PM   #1
colinsv25
Default swing arm bush
hi ppl took my k4 pointy for its 1st m.o.t today its passed but ive been told that the swing arm bush's need replacin.
can any1 tell me roughly hpw much they will cost and will i ave to go to main dealer.
many thanks
Old 23-11-07, 10:29 PM   #2
Default Re: swing arm bush
glad it passed for you mate, (its a k3 by the way) ive never herd of swing arm bushes needing replacement?
Old 23-11-07, 10:49 PM   #3
not too hard a job if you've got some threaded bar and big washers kicking around.
Also a selection of bits of bar to prop the back of the bike up
Old 24-11-07, 07:18 PM   #4
colinsv25
i was told i might ave to go to main dealer to get them,i told them about the accident kwak and they said it might ave been that which caused it or going round corners a high speeds,by the sounds of it it aint an hard job
Old 24-11-07, 07:26 PM   #5
You'll probably have to buy them from suzuki, I haven't heard of an aftermarket source, where fits them is a different matter.
Not sure how high speed cornering damages bearings though, thats what they're designed for!
Old 24-11-07, 11:01 PM   #6
me narr not me
Old 25-11-07, 05:19 AM   #7
kcowgergmm
talking of bushings how would you recommend getting wheel bearings out im going to powder coat them
Old 25-11-07, 05:40 AM   #8
rictus01
rictus01's Avatar
Couple of things, mine never needed changing in 153,000 miles, I looked at them at 50,000/100,000 and 150,000, and they were still good, that said I did originally when I got the bike grease them as Mr Suzuki is a bit tight with the old grease when they come from the factory, and regularly re-greased.
Fitting can be done quite easily with either a press (which you probably haven't got) or creative use of a good vice and some spacers.
Cheers Mark.
Old 25-11-07, 04:13 PM   #9
Don't know how to get them out without use of a punch, which will mean you need new ones.
Old 26-11-07, 04:01 PM   #10
Aye, I've always just mullered them out with my Big Hammer and a punch.
When the brakes are not strong enough, use a bush... Seggons Photos 118 17-06-08 03:58 PM
gear lever bush? dizzyblonde SV Talk, Tuning & Tweaking 11 18-03-08 12:10 PM
Kate Bush - You a fan? ThEGr33k Bikes - Talk & Issues 12 10-01-08 01:50 PM
Bush Declares War On Bird Flu . . . Supervox Idle Banter 0 16-06-06 02:25 PM
bush gag...could be old keithd Idle Banter 10 10-02-06 07:00 PM
