Old 26-11-07, 11:33 PM   #1
pencil shavings
Default seeing in the rain!
ive always wondered how other bikers deal with heavyish prolonged rain, to the point where rain on the visor actualy restricts your view?
At slower speeds I just use my left hand to wipe my visor. When im going along with a bit of speed I find that if I tilt my head slightly to the right or left the wind blast will blow the rain off the visor and I dont need to use my hand.
anyone have any better/different methods?
Old 26-11-07, 11:44 PM   #2
Beenz
Default Re: seeing in the rain!
Thats what I do as well.
Old 26-11-07, 11:50 PM   #3
About the same, that or at a stop open and close the visor a few times, the ratchet tends to flick the drops off.
Old 27-11-07, 08:02 AM   #4
gettin2dizzy
Ride faster!
You can get anti-rain sprays on the visors which are meant to help
Old 27-11-07, 09:14 AM   #5
tricky
Eat more carrots ?
I'll get me coat........
Old 27-11-07, 09:17 AM   #6
Alpinestarhero
At the moment, I am doing a project for my final year at uni looking into making the visor more water repellant. I have an experiment coming up (getting the stuff ordered to do it) which might well work, although the materials involed (fluoroalkylsilanes) could make the method expensive. We'll see though how it pans out. My research has been inspired by not bieng able to see when I am riding in the wet weather.
I'll keep the .org posted
Matt
Old 27-11-07, 09:20 AM   #7
pencil shavings
Originally Posted by tricky View Post
Eat more carrots ?
didnt say anything about the dark, only the rain
Old 27-11-07, 09:21 AM   #8
pencil shavings
Matt
sounds like a good idea, I think there would definatly be a market for anti rain products!
Old 27-11-07, 09:27 AM   #9
Dicky Ticker
I use silicone spray on a clean visor,let it dry and then polish up.Not 100% but def better than nothing at all as it needs less wind force to shift the spray. If you have a faired bike put your head directly in the airstream off the screen and with the silicone spray it clears immediately
Old 27-11-07, 09:37 AM   #10
Alpinestarhero
Dicky ticker hit on a very good point; the silicone stuff (based on polysiloxanes) is a great water-repellant material, problem is it collects dirt and other crap, and is not permanent - I'm aiming to try and make a permanent coating, much like the hard / anti-scratch coating thats already present on the visor surface (this is commonly a silica-based coating).
The effect should be the same, the water will not adhere to the surface as strongly, and the water should run off easily There probably is a market, and to be honest I dont know why there isnt already such things avaliable; its possibly due to the coating not being hard enough and prone to scratches, but I'll have to investigate that at a later stage.
Matt
Will the rain ever end??? Kate Moss Idle Banter 22 07-07-07 11:34 AM
Rain Rain, Go Away... the backup plan! Ping 2007 Annual Rideout 39 29-06-07 09:31 AM
SVs in the rain. Taipan SV Talk, Tuning & Tweaking 15 13-05-07 03:53 AM
i'm fed up with rain now :( kwak zzr Idle Banter 13 12-05-07 11:52 AM
sv and the rain BIKER-DENE SV Talk, Tuning & Tweaking 6 17-02-06 07:32 AM
