Old 04-12-07, 01:28 PM   #1
Hockeynut
Question Checking Oil, lower fairing on Curvey
I'll admit I'm not great at the maintenance side of things. I have a 2000 plate curvey. Trouble is recently I noticed a few drips of oil on the garage floor from where the SV's been sat for a few days.
So I need to check the oil situation out (something I know I should be doing more regularly anyway ), make sure it's not got too low or anything. From what I can tell I'm going to have to remove the lower fairings just to see this, is that right? And are they easy to remove/refit?
Think I'll need my first socket set for xmas! XD
HN.
Old 04-12-07, 02:35 PM   #2
jambo
jambo's Avatar
Default Re: Checking Oil, lower fairing on Curvey
Get someone to hold it level, most of the lowers have a hole to see the spy glass (on the right side of the engine below the oil filler cap). You may need a torch but you should be able to see it. I don't like lowers because of this....
Old 04-12-07, 02:54 PM   #3
fizzwheel
fizzwheel's Avatar
When I had lowers on my curvey I never needed to take them off to check the oil level, I dont have to when I check the oil on my other halfs K5 SVS with lowers either.
If you kneel down on the brake side of the bike one knee of the ground by the footpeg. Grab hold the front brake lever with your right hand and hold the brake on, then grab hold the footpeg with your left and the pull the bike up towards you off the side stand, do it gently and you'll find it'll come up onto the balance point. Now because your knelt down the site glass will be roughly at eye level and its an easy job to check the level.
Old 04-12-07, 02:58 PM   #4
Dangerous Dave
I agree....
Also check around the clutch cover, especially its bolts, and the engine cover it mounts to for traces of oil. A lot of people seem to have difficulty in refitting the clutch cover properly for some unknown reason.
brackets for lower fairing on curvey maclovin Stuff Wanted 4 16-09-09 04:58 AM
Lower Fairing for curvey SV650S austin1 Stuff Wanted 4 17-04-09 10:39 PM
Curvey lower fairing "scoops". St0rmer66 Stuff Wanted 1 15-07-08 05:09 PM
Curvey lower fairing OLDBOY RACING Stuff Wanted 9 03-12-07 05:17 PM
Lower fairing inlet scoop screw & top fairing clip Mr. Marcus Stuff Wanted 2 05-12-05 09:18 PM
