I've managed to snap an exhaust stud on my Hornet 600 removing a blown downpipe
![]() Thanks. |
Try JHS Racing, they are based on the A4 just outside of Bristol in Keynsham. Friendly guys, fantastic service, well respected....
Web: www.jhsracing.co.uk Tel: 0117 986 8844 Email: jhsracing@lineone.net JHS Racing Unit 3, Unity Court, Broadmead Lane, Keynsham, Bristol, BS31 1ST |
Has the easy out wedged in the stud or have you got that out?
If it is still in then you will probably have to get an engineer to get it out. If you can get the extractor out, try drilling the hole with progressivly bigger drills untill the edge of the hole breakes through side of the thread. in some casses the drill will grab onto the stud and release it, but not often. once you can see the thread down the side of the hole, you may be able to pick the other threads out whith something small and sharp (scriber/small screwdriver) then its a case of running a tap down the threads to clean up any damage, be careful to keep the tap square and not to cross thread the hole. max hole dia for M6 stud is 5mm max hole dia for M8 stud is 6.8mm max hole dia for M10 stud is 8.5mm these are for standard coarse pitch threads When drilling studs, if possible grind the end flat. always spend a great deal of time to center punch in the center of the stud, it makes things alot easier, and try to drill down the center. If all of this still does not work. the next step is to fit a thread insert into the hole, this involes drilling the hole bigger, tapping new threads in the hole with a special tap and screwing in what appears to be a spring that brings the threads back to the correct size. this method can produce stronger threads that the originals. If in ANY doubt, contact a local engineering company, dont forget, if it goes wrong it could get alot more expensive |
You could try Steve at Piston Broke in Easton. He's done loads of stuff for me over the years and I rate him.
Piston Broke Engineering Unit 13/15 Felix Road Easton Business Centre Bristol BS5 0HE ![]() Avon Tel: 0117 941 2300
http://ridingalongwayslowly.blogspot.co.uk/ 3x Honda C110 - phut-phut-phut KTM Duke 690 - brum-braaaaaaa!!!!! BSA C25 - brum-braa-braa RD350LC Ring-ding-phut-clatter-££££££ |
there is a motorcycle engineering company based at Avondale works in Kingswood off Woodland way.Will go round tomorrow and get their correct details if you want.
Philbut - the engineer | KnightRider | Thames Valley | 4 | 19-12-08 05:34 PM |
Wanted : Mathematician or Heating Engineer | Mr Toad | Idle Banter | 16 | 08-08-07 04:21 PM |
