Old 01-01-08, 09:39 PM   #1
gdharbourne
Default more starting problems
recently changed the starter motor in my sv curvy due to starting problems. but it made no difference, i was told to change the solenoid which i did but it is still not starting. battery is fine, alarm is not faulty and everything else seems to be ok. any suggestions??
Old 01-01-08, 09:46 PM   #2
ridelikeaturtle
Default Re: more starting problems
you've double-checked all the connections are good, and all the fuses are OK, not forgetting the main fuse? Try the neutral-safety switches --at the clutch lever, and the sidestand; also check and clean the kill switch.
Old 01-01-08, 10:00 PM   #3
hovis
how is it not starting?
is it turning over?
are the dash lights comming on?
etc
Starting problems with my Sv 650 K3 -pATz- SV Talk, Tuning & Tweaking 5 30-03-06 08:30 PM
Problems starting riktherider SV Talk, Tuning & Tweaking 4 11-06-05 06:13 PM
Starting problems squirrel_hunter SV Talk, Tuning & Tweaking 2 14-05-05 09:37 PM
starting problems JakeRS SV Talk, Tuning & Tweaking 4 02-05-05 01:04 PM
Starting problems... Aaron SV Talk, Tuning & Tweaking 9 22-12-04 07:45 PM
